Horrible noise!!
Old Mar 31, 2010 | 08:23 PM
pearlvett's Avatar
pearlvett
Default Horrible noise!!
Ok so im getting a horrible squeaking noise from under the hood. I just got a used air pump elim. and i think it might be the pully on that because it was making a slight grind noise when i would turn it by hand. Where could i find a replacement and what else should i look at? Any help would be nice as its starting to get embarassing!
Old Mar 31, 2010 | 08:29 PM
383vett's Avatar
383vett
If that is the only change you made and the belts are lined up correctly, your pulley bearing is shot. Go to Autozone and have them match up a pulley that will work. That is what I did when I changed the configuration of my eliminator to work with an idler pulley instead of a regular pulley so I could run an electric water pump.
Old Mar 31, 2010 | 08:40 PM
pearlvett's Avatar
pearlvett
Ok so auto zone has a selection of pullys? I did not know that...do you think they will have the one i need?
Old Mar 31, 2010 | 09:09 PM
pearlvett's Avatar
pearlvett
Also could this be caused by a bad tensioner? Just another thing i remembered...
Old Mar 31, 2010 | 09:51 PM
car5car's Avatar
car5car
For some reason even experienced mechanics sometimes don't have stethoscope. I bought extra one from Harbor Freight for $3.
It takes about 1 min to diagnose tentioners, bad alternator and compressor bearings, steering pumps etc.
Old Mar 31, 2010 | 09:54 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
^^^Good Advice^^^
Old Apr 1, 2010 | 12:09 AM
pearlvett's Avatar
pearlvett
I just use a rubber tube usually but i dont have one here at college with me so thats why im kinda takn shots in the dark...
To Horrible noise!!
