Having a real bad day, 1st my laptop and now this.
Was checking header bolt torque when I heard something hit the pan under the master cylinder.
And low and behold, I knocked the connector out of the master cylinder, not the one in the resevoir.
Anyway, I went looking for the connector and I cannot find it or the wires(yes, it has been that type of day), so anybody w/92-94 can you tell me which harness these 2 wires originate?
I just looked at my 93 and the double wire connector goes to the fluid level switch in the reservoir, there is a single wire connector that goes to the pressure differential switch in the body of the master, both sets of wires originate in the small harness that goes to the ASR servo. Hope that helps.
