383 to 406...should I?
Old Apr 1, 2010 | 07:40 PM
Snakecharmer383's Avatar
Snakecharmer383
Default 383 to 406...should I?
Seriously kicking around the idea (depending on price) of going to a 406c.i. from my current 383. Im thinking I would just get a 406 short block from LPE and use my current heads/intake setup.
Anyone wanna help me make a decision?
Old Apr 1, 2010 | 08:32 PM
383vett's Avatar
383vett
I did and I'm happy. I used the same heads and am just under a half second quicker. Still using the SuperRam too.
Old Apr 1, 2010 | 08:34 PM
88BlackZ-51's Avatar
88BlackZ-51
why not 421,420, or 434?
Old Apr 1, 2010 | 08:42 PM
LD85's Avatar
LD85
depends on the block the uses really
tpi 421 vette's Avatar
tpi 421 vette
More cubes the better for our heavy street cars. You will like that 4.125+(probably 4.155") bore, and you might consider stroking it.
Old Apr 1, 2010 | 09:13 PM
cumbercr's Avatar
cumbercr
A Dart 400 is on my wish list (4.125 x 3.75). I'm thinking my AFR 195s and SR will go well. The smaller bore leaves room to bore it again in another 100K. I'm trying to figure out how to cam it.
Old Apr 3, 2010 | 11:48 PM
Snakecharmer383
I was actually thinking that after I posted this about the 421 or 434. Recieved email back from LPE and doesn't seem like a 406 is even a option from them. He suggested a GM LS2 or LS3 crate engine. So I guess I'll have to do some more research.
Old Apr 4, 2010 | 01:38 AM
USAsOnlyWay's Avatar
USAsOnlyWay
Dart SHP...421. Do it. I wish I could.
Old Apr 4, 2010 | 01:51 AM
mnstrlt1's Avatar
mnstrlt1
that's pretty interesting that even LPE is suggesting going Ls-x swap instead of big-inch traditional small block?
Depending on what you're looking to spend, the options are WIDE open....
BTW- just to toss fuel on the fire, RHS currently builds a tall-deck Ls-x that can support 500 cubic inches...
Old Apr 4, 2010 | 11:00 PM
tpi 421 vette
LPE doesn't do anything on first gen sbc's anymore. That doesn't mean you can't make big power with a first gen engine. I am sure they are trying to make a sale. There are still a ton of options for first gen engines, and the wiring and computers will hook right up, and the engine bolts right in.
Old Apr 4, 2010 | 11:07 PM
Calderone's Avatar
Calderone
421 all the way !!!
Old Apr 4, 2010 | 11:32 PM
cv67's Avatar
cv67
St. Jude Donor '05
Figures whatever is easiest for them.
Try the Dart block youll love it. Very nice piece.
Old Apr 5, 2010 | 06:05 AM
Snakecharmer383
Thanks for the info guys and the PMs with info also.
Old Apr 5, 2010 | 08:35 AM
BLOCKMAN's Avatar
BLOCKMAN
We have a build coming up in the next month or so and I am trying to talk the customer into a set of the Profilers.
http://www.profilerperformance.com/sbc-heads-176.html
A Dart block is the way to go!!!!!!!!!
Old Apr 5, 2010 | 09:42 AM
LD85's Avatar
LD85
[QUOTE=BLOCKMAN;1573656407]
A Dart block is the way to go!!!!!!!!![/QUOTE
Blockman, what about a Bowtie block for a 421?
Old Apr 5, 2010 | 11:20 AM
BLOCKMAN's Avatar
BLOCKMAN
[QUOTE=LD85;1573656925]
The Bowtie blocks are a good choice if you can find one as they are hard to get right now and they seem rather pricey over the Dart blocks!!
They need a lot more clearancing then the Dart blocks!!!
Old Apr 6, 2010 | 04:48 AM
88BlackZ-51
Why now ask Jim if he will build you a 421?
Old Apr 6, 2010 | 06:52 AM
Calderone's Avatar
Calderone
Ask Jim !!!
tpi421vette is the way to go !!!
Old Apr 6, 2010 | 01:03 PM
Orr89rocz's Avatar
Orr89rocz
I love my dart SHP 400 block. Just like OEM roller blocks but 2pc rear main. Works good on my turbo car. 4.125 bores love air flow, so get a decent 210-220cc head. I wish I would have, but for now i'm stuck with my 195's.
To 383 to 406...should I?
