Coolant question
Old Apr 1, 2010 | 09:26 PM
kmhene's Avatar
kmhene
Default Coolant question
Tonight I pulled into the garage and shut my car off. Right before I turned it off the fans kicked on and the temp was 224. After I got out I went inside and came back out and heard the overflow bottle bubbling. I opened it up and it looked normal. I am assuming it was just hot from me turning it off when it was hot.
Had anyone had this happen? Is there a problem or is it because I turned it off hot?
Kevin
Old Apr 1, 2010 | 09:35 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
What your hearing is normal.
Quite a few cooling systems will do that.
Your fine, as long as you didn't see any leaks.
Old Apr 1, 2010 | 09:40 PM
The Green Rocket's Avatar
The Green Rocket
Virtually always, your coolant temperature will increase after you shut the engine off - because the coolant is no longer circulating. That is where your overflow tank comes into play. Have you noticed that it has a "Hot" level and a "Cold" level? Just check it later when it has cooled off and I'll bet the overflow leve has dropped.
Unless it leaves a puddle on the floor, or unless you have to keep topping off the coolant, then there is no problem.
Thomas
Old Apr 1, 2010 | 09:55 PM
kmhene's Avatar
kmhene
Oh no, no leaks or anything like that. Its just the first time I actually heard it. I know about the hot and cold levels on thr stick. Its just funny that I never heard it before.
Thxs for replying guys. I appreciate the help.
Kevin
To Coolant question
