Differential Fluid Change
Old Apr 2, 2010 | 03:20 PM
M.J.L.'s Avatar
M.J.L.
St. Jude Donor '10-'11
Default Differential Fluid Change
Mechanic is going to drop the cover, drain and replace fluid, and replace the "posi" and seal it back up for 75 dollars. Is this for real? Seems really cheap....
FYI, no I am not going to try to tackle this project myself....Rather let the mechaic do it. He has never let me down oh btw, it's a D36.
Old Apr 2, 2010 | 03:40 PM
jhammons01's Avatar
jhammons01
Your mechanic is smoking crack.
he obviously has no clue about the D36, or he is yanking your chain and never intends to do anything.
How would 99.999% of the population check the fluid on a D36 to see if it was fresh or not?
And what "Posi" would he be referring to?? The Carrier?? It cost $75 just to call anyone that has D36 parts much less actually order any of them
Old Apr 2, 2010 | 03:50 PM
STL94LT1's Avatar
STL94LT1
Don't think your mechanic has a clue about the rear end in your car.
Old Apr 2, 2010 | 03:56 PM
surfer92's Avatar
surfer92
Think he means posi lube.
It is a 15 minute job to pump out old fluid and the pump in 1.5 quarts of gear oil and 4 oz of posi lube.
Total cost $8-9 oil
$6 lube
Yeah, you can check the level using the old finger technique, unscrew the filler plug while the right wheel is higher then left, insert finger.
If you do not touch fluid, fluid is low.
Old Apr 2, 2010 | 04:14 PM
C4boy's Avatar
C4boy
For $75, let him do it. The price is more than fair. And don't forget, 2 tubes of posi additive.
Old Apr 2, 2010 | 04:27 PM
M.J.L.'s Avatar
M.J.L.
I told him I wanted a fluid change and he said hed drop the cover and change it that way and mentioned something about a positive? and I said posi and he said yes and said something about replacing something to do with that? Must be the lube....Fluid change sounds good. Thanks guys!
Old Apr 2, 2010 | 04:34 PM
jon0108's Avatar
jon0108
What cover? there isnt any
Old Apr 2, 2010 | 04:35 PM
STL94LT1's Avatar
STL94LT1
Old Apr 2, 2010 | 04:51 PM
C4boy's Avatar
C4boy
Sure there is. Granted, there's a big old batwing in the way, but there's still a cover. Oakley's mechanic will realize it's easier to pump out the old fluid once he looks at it, but the end result is the same and the price is fair.
Old Apr 2, 2010 | 07:13 PM
383vett's Avatar
383vett
If all he is going to do is pump the fluid out and refill, you should do it yourself, save half and have a pump left over for next time. He probably doesn't realize that the IRS rearend is unlike most other live axle rears.
Old Apr 2, 2010 | 10:10 PM
l98tpi's Avatar
l98tpi
Max G’s
To Differential Fluid Change
