what sealant on coolant temp sensor?
Apr 4, 2010 | 04:48 PM
Planning on replacing the Coolant temp sensor on dads 93 tomorrow, and just wanted to know if I should use sealant on the threads and if so should I use teflon tape or permatex high temp red sealant?
When the car reaches operating temp it idles bad, appears to have a miss, and stumbles and backfires when any amount of throttle is applied so Im assuming coolant temp sensor or ecm, as o2 and knock sensors have been replaced.
Apr 4, 2010 | 05:02 PM
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
thread sealant
Apr 4, 2010 | 08:46 PM
C4 of Year Winner (appearance mods) 2019
Didn't I hear/read that a temp sensor comes with sealant on the threads -- and that it should not be augmented (at the risk of losing ground)?
Apr 5, 2010 | 12:28 AM
I thought it should come with thread sealant too but it did not
Apr 5, 2010 | 12:31 AM
Apr 5, 2010 | 12:52 AM
Cruise-In II Veteran
Quote:
Originally Posted by
GREGGPENN
This happened to me with a Knock sensor.I put that tape on it,because I was worried about a coolant leak and it prevented it from grounding.
I took it off and put the sensor back in by itself and it worked,did not leak either.I also replaced the fan switch and others with no tape or rtv and they never leaked.
Apr 5, 2010 | 08:37 AM
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
If it does not come with sealant already applied then use the Permatex sealer.
I think if you use RTV it will disrupt the ground for the sensor.
Apr 5, 2010 | 08:47 AM
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
If you use RTV you could do only the last couple threads that way the first ones are grounding.
Apr 5, 2010 | 11:11 AM
Kubs
RTV isn't designed to seal threads though.
Apr 5, 2010 | 11:23 AM
joshwilson3
RTV or sealant I guess I should have said.
Apr 5, 2010 | 12:07 PM
Kubs
Yeah, but RTV shouldn't even be used at all to seal threads.
Apr 5, 2010 | 12:11 PM
sounds good thanks for the help
Apr 5, 2010 | 06:14 PM
I use teflon tape on all of them (my previous 86, my current 96 and even my son's 96) leaving the fore-most three threads uncovered.
The 86 FSM specifically calls for Teflon tape on the knock sensor.
Jake
Apr 5, 2010 | 07:03 PM
2017 C4 of Year
I've done the job three times (head and pump) with thread sealant and it works fine. A new sensor comes with it.
Apr 5, 2010 | 07:11 PM
If I do use teflon tape, I only use it on half the threads.
Apr 5, 2010 | 07:16 PM
From: One day you're a Comet...the next day you're dust... Arkansas
Apr 5, 2010 | 08:23 PM
Installed new one today didnt have any sealant on it so used teflon tape. no apparent problems
Apr 5, 2010 | 08:33 PM
JAKE
Jake
Huh, I've read that you shouldn't put anything on the knock sensor as it can interfere with it detecting knocks. The AC Delco knock sensor I put on mine had some red sealant stuff already on the threads. So I didn't add anything, and I get no leaks. I also torqued it to spec, as I've read that is also a good idea with regards to the knock sensor.
Apr 5, 2010 | 09:02 PM
JAKE
Even fully wrapped , when you remove the sensor you can see the thread has cut the tape and sensor has had a solid connection along it's full length
1995 ,
96 ,
chevy ,
coolant ,
corvette ,
high ,
location ,
permatex ,
sealant ,
sender ,
sensor ,
temp ,
temperature ,
thread ,
threads
