Stock coil or high perf.
Old Mar 13, 2002 | 06:13 PM
poppy's Avatar
poppy
Cruise-In III Veteran
Default Stock coil or high perf.
My ignition coil is suspect for the problems I'm having so if I take it to the local Autozone to be tested I would feel obligated to buy theirs . Although they might have the o.e.m. the one that is in it now is a Hypertech Street/Strip. My question is should I get a high performance coil or would the stock o.e.m. be good enough because I want to be on the road this weekend?
Old Mar 13, 2002 | 06:27 PM
TIMSPEED's Avatar
TIMSPEED
Default Re: Stock coil or high perf. (poppy)
Hmm..I have the Hypertech coil in my car, and I've run it in my car for over a year now, and it's never skipped a beat. It's a much smoother idle than stock, I'll have to admit.
Old Mar 13, 2002 | 06:30 PM
J Z06's Avatar
J Z06
I have a stock unit on my 383. I do have a Hypertech one awaiting installation. Once the transmission is done, it's going on with a set of new plugs wires and cap and rotor. I'll let you know how it performs. I only heard good things which is why I bought one.
Old Mar 13, 2002 | 08:35 PM
vader86's Avatar
vader86
OEM is fine unless you have major mods that require better ignition parts.
Old Mar 13, 2002 | 09:04 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Stock coil or high perf. (vader86)
I'm still running my original/OEM coil and it's still working fine.
Old Mar 14, 2002 | 02:56 AM
jay17's Avatar
jay17
Default Re: Stock coil or high perf. (mackeyred96)
I replaced mine with the stock coil. So far, so good.
Old Mar 14, 2002 | 03:03 AM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
That's pretty much what I heard. After I swapped to a DUI ignition module and street/strip coil I did notice the idle seemed a bit smoother though.
[Modified by Red 90 L98 Coupe, 5:05 PM 3/14/2002]
Old Mar 14, 2002 | 06:39 AM
poppy's Avatar
poppy
Thanks guys
Old Mar 14, 2002 | 02:04 PM
Greg Johnson's Avatar
Greg Johnson
Default Re: Stock coil or high perf. (Red 90 L98 Coupe)
If Mackey is still running the stock coil, most of us don't need anything else. I know the stock coil soes a real good job.
Greg
Old Mar 14, 2002 | 10:09 PM
R23HTC's Avatar
R23HTC
Default Re: Stock coil or high perf. (Greg Johnson)
I can say this. DO NOT use a MSD Blaster with STOCK wires! Burnt my coil wire in two! I now have MSD 8.5mm wires!
To Stock coil or high perf.
