91 C4 engine trouble
Old Apr 6, 2010 | 11:50 AM
cessnaking2001's Avatar
cessnaking2001
5th Gear
Default 91 C4 engine trouble
i have a 1991 corvette with an L-98 ...its been sitting for over a year and finally have the time to tinker with it ... i changed the fuel pump and fuel filter,I use some starting fluid to start it and it starts right up runs strong for about 20 min and then shuts down completely with no prior sign, it doesn`t run rough or anything just shuts off and wont start back up for a few days.i changed the top half of the distributor and still the same. i`m really confused on what it could be.. i was thinking maybe the fuel pump or fuel pump relay any help would be great !
~sean
Old Apr 6, 2010 | 01:42 PM
CanadianC4Vert's Avatar
CanadianC4Vert
Is it throwing any codes?
Old Apr 6, 2010 | 02:08 PM
Jamesnns's Avatar
Jamesnns
Your batt probs got enough in it to start it but then not enough to keep it running. After all you say it's been sitting for a year or more. Take batt to AZ or somewhere and have it load tested.
I'd dump the fuel too, bad gas after a year aint good.
Old Apr 6, 2010 | 02:10 PM
car5car's Avatar
car5car
Remove fuel pump relay and try to start with starting fluid.
Old Apr 6, 2010 | 02:14 PM
Jamesnns's Avatar
Jamesnns
Check your coolant and T-stat and water pump. High temp will cause your car to shut down by itself.
The top coolant hose should get hot and firm at temp.
Just cause maybe your temp gauge shows OK, maybe not so?
Old Apr 7, 2010 | 09:54 AM
cessnaking2001
5th Gear
the Battery is brand new and i dumped the old fuel and replaced it with new premium gas .. the fuel pump is new....i don't have anything to check the codes.
Old Apr 7, 2010 | 09:55 AM
cessnaking2001
5th Gear
its really starting to **** me off ha ha...I'm thinking about getting hauled off and looked at by pro ... i was hopping to get it going the cheaper way
Old Apr 7, 2010 | 10:00 AM
Jamesnns's Avatar
Jamesnns
Sure you do, takes less than 5 min.
Just under your steering wheel, right about knee level, you'll find your connector box for reading your codes
Stick one end of a paperclip in slot A, and the other end in slot G, turn key to ON, do not start car.For a 91.
[F|E|D|C|B|A]
[G|H|J|K|L|M]
Short pin A to pin G
Turn ignition On
LCD will display codes.
1.0 are codes for CCM
4.0 are codes for ECM
7.0 are codes for Active Suspension Should show ERR which is normal
Do this asap and report back with any codes that show up, they'll be where your speedo is.
Old Apr 7, 2010 | 10:01 AM
CanadianC4Vert
You can check the codes by jumpering the diagnostic port. Do you have a manual for the car? It will tell you how this is done, or I am sure it is on here somewhere if you do a search.
Old Apr 7, 2010 | 10:02 AM
cessnaking2001
5th Gear
i'm at work right now i'll check it when i get home and thanks for the info !!!!
Old Apr 7, 2010 | 10:04 AM
CanadianC4Vert
Originally Posted by Jamesnns
[/B]
[F|E|D|C|B|A]
[G|H|J|K|L|M]
Turn ignition On
Must have beat ne to the enter key
Old Apr 7, 2010 | 10:06 AM
Jamesnns's Avatar
Jamesnns
Nayh...nayh...nayh...I got to it first...LOL.................
I actually got to help someone, SEE, and old dog CAN learn new tricks.
Old Apr 7, 2010 | 10:07 AM
CanadianC4Vert
Old Apr 7, 2010 | 10:14 AM
cessnaking2001
5th Gear
heck i love this car!! it was my first car..so i want to restore it to its former glory ,not much work really new tires and new seats really and a little engine dressup ... my wife is an avid corvette fan but she wants a '72 stingray ..would be nice but they are a bit pricey right now but we have a kid and mortgage so that takes the $$ away lol
Old Jun 1, 2011 | 03:27 PM
vette079's Avatar
vette079
Check resistance on the injectors, info on this forum.
If low resistance on a few, JON at FIC time!!!
Old Jun 1, 2011 | 04:15 PM
Keystring's Avatar
Keystring
Sounds like you have a bad Ignition Control Module.
To 91 C4 engine trouble
