why me?
Old Mar 13, 2002 | 07:51 PM
Jasin9687's Avatar
Jasin9687
Default why me?
I just bought a 96 LT4, mint car, but today I decided to take it for a ride with a friend and boom, check engine light, so I thought instead of risking it Id take it in to be put on the machine. The mechanic came back and said "sir come with me" it turns out all 8 cylinders are misfiring, he said it could be anything from bad fuel injectors to a small hole in the intake, what a day! I think Im gonna go cry now lol, I had to cancel my spring break and everything so I can try and save up money to have more damn tests done..... Grrr :mad
Old Mar 13, 2002 | 07:53 PM
robsvette's Avatar
robsvette
Default Re: why me? (Jasin9687)
c4 section would get u more help. i feel for ya
Old Mar 13, 2002 | 08:00 PM
David Lively's Avatar
David Lively
See the C4 section, but think about this: what are the odds of ALL EIGHT injectors going at the same time? The "hole in your intake" idea is interesting, but how on earth would that happen?!?!
Sounds more like a computer problem to me.
Old Mar 13, 2002 | 10:45 PM
redcorvette1995's Avatar
redcorvette1995
I agree.
I had a similar problem on my C4 and a buddy
had it happen on his LT1 Camaro. In my case
it was a bad PCM (try a swap and see if it fixes it)
and in my buddy's case it was a cam position sensor.
$60 part and hour and a bit to install (once they found it).
The trick is finding a mechanic who knows what the problem is.
They are out there, maybe a vendor or someone will see thing
and give you some good advise.
Old Mar 13, 2002 | 11:36 PM
purple jinx's Avatar
purple jinx
can you find out exactly which code its throwing ? then you could throw the code number out there and someone can help you understand what your car is trying to tell you. alot of codes can be cleared fairly easily and you can save some of your cash. good luck... :cheers:
Old Mar 13, 2002 | 11:44 PM
rcdk's Avatar
rcdk
Ok, the check engine light came on. What else?
Did it seem to be running ok? Unless you noticed a real big problem, I would have a hard time believing the mechanic.
I just bought my LT4 and the other day the engine light came on, no other symptoms. So I stopped and Got an OBD II scanner for $150.
Turned out to be a $20 AIR check valve.
I have had too many mechanics try to scam me for hundreds or even thousands of dollars when the problem could be fixed with a $20 bill. :mad
Now I don't even bother taking a car in unless I know exactly what the problem is and it is something I can't do myself.
Old Mar 13, 2002 | 11:52 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Could be something as simple as an ignition wire rubbing against teh water pump. That's what happened to me. Maybe Opti is on it's way out, but if teh check engine light came on, it could be the PCM.
Old Mar 14, 2002 | 02:16 PM
35th's Avatar
35th
Default Re: why me? (Mr Mojo)
Seems like U may be able 2 keep more money than U thought and still be able 2 get that Spring Break in. Get another opinion, maybe from a shop in your area that work on Vettes or high performance cars. :cheers:
Old Mar 17, 2002 | 06:31 PM
Jasin9687's Avatar
Jasin9687
cool guys thanks, um, ill get the codes, Gotta go look for um, then Ill post them maybe some of u guys have seen them b4
Old Mar 17, 2002 | 08:47 PM
Jasin9687's Avatar
Jasin9687
The codes are P0300 and P1652, I know that P0300 is a multiple engine misfire and Im not sure where to start lookin for the problems..... Grrrrrr
To why me?
