88, invisable coolant leak help !!
Old Apr 6, 2010 | 09:29 PM
foreveraudio's Avatar
foreveraudio
Default 88, invisable coolant leak help !!
ok im a new vette owner, just bought one 3 weeks ago.
a 88 c4
well i just recently noticed coolant leaking, figured it was the water pump so i bought and installed a new one.
still leaks, hoses look fine, everything seems to be fine and i cant see where its leaking from, so today i took it to a shop and they did a pressure test, it hardly leaked during the pressure test, but while car is running it leaks more.
they couldnt figure out where it s coming from either.
all i can tell is that is coming from the right hand side of the car, and near the bottom, cant see where because of that support that goes across the bottom.
there is no signs of coolant anywhere except on the support beam at bottom of car.
freeze plugs are fine, hoses are fine, nothing visable around waterpump, ect.
i dont know what else to do
Old Apr 7, 2010 | 11:12 AM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Could be from the front corner of the intake manifold. Basically you need to start taking things apart until you find the leak.
Old Apr 7, 2010 | 05:35 PM
foreveraudio
Default its coming from bottom
so im out there looking over things, cant see anything except for the drip , it appears to be coming from center of engine bottom, near the lower most pully in the center
anyone know whats down there that could cause a coolant leak ?
Old Apr 8, 2010 | 12:18 AM
HdRider04's Avatar
HdRider04
I had a small coolant leak that I could never find as well. It showed up front middle of the car. Still had it after the wp was replaced. Yesterday I had to replace the coolant line that goes to the TB because of a split in it and now no little puddle under the car in the mornings.
Old Apr 8, 2010 | 12:56 AM
foreveraudio
Default ok
ill check the line that gpes to the throttle body in the morning and see if that shows anything
Old Apr 8, 2010 | 10:16 PM
foreveraudio
Default nope
everything checks out, i gave up took it to the dealership today, see if they can find it, its driving me nutty
Old Apr 9, 2010 | 10:06 AM
HlhnEast's Avatar
HlhnEast
Recheck the freeze plugs, they are really hard to see. All your heater hoses are on that side too, my control valve has a small drip at the packing. Bypass the TB if you havent yet, dont think you have to worry too much about freeze ups in DFW Water is funny, it will drip a good ways from the source. Start at the lowest point you see water and keep going up til its dry. I am a plumber and its rarely where you see the drip to start with.
I didnt want to do it but one of my freeze plugs had a drip and I put sealer in the system and stopped the problem. No drips after a year.
Good luck!
Old Apr 9, 2010 | 11:05 AM
Millah's Avatar
Millah
Check all your hoses. If that dont work try some stop leak.
Old Apr 9, 2010 | 02:41 PM
CAJUN C4's Avatar
CAJUN C4
Bar's is the Best...It's put in some New Cars from the factory
http://www.barsproducts.com/C16_R6.htm
Old Apr 9, 2010 | 08:52 PM
jfb's Avatar
jfb
C4's are famous for head gasket leaks. Look all the way around the head gasket gap. If you have to replace the head gaskets, use the Fel-Pro teflon coated head gaskets, they last a long time.
To 88, invisable coolant leak help !!
