factory alarm
Old Mar 13, 2002 | 10:35 PM
Raidmagic's Avatar
Raidmagic
Default factory alarm
I just bought an aftermarket alarm with keyless entry and the factory alarm goes off when I try to enter with out manually unlock the doors. So my question is is there a way to bypass or unhook the factory alarm??
It is ane '87
Old Mar 13, 2002 | 10:43 PM
Bluevette85's Avatar
Bluevette85
Default Re: factory alarm (Steve87VETTE)
You need to connect a diode (1N4001) from the door unlock signal of the keyless system to pin H of the Theft Deterrent Module which is located behind the dash below the breadbox infront of the ECM housing. This will provide a ground pulse to disable the alarm just like turning the keylock would.
