Open Loop....
Old Apr 10, 2010 | 06:19 PM
Weav's Vet's Avatar
Weav's Vet
Default Open Loop....
What are the advantages/disadvantages of running in open loop all the time?
Old Apr 10, 2010 | 06:22 PM
vetteguy216's Avatar
vetteguy216
I think it would be a disadvantage if you had to run in closed loop all the time, as your car would be running off of a preset values and not using any of the sensors.
Old Apr 10, 2010 | 06:27 PM
Weav's Vet's Avatar
Weav's Vet
There are some that do run in open loop all the time though. I was just curious because my throttle response seems to be so much better when it is in open rather than closed loop. Also the idle is better.
Old Apr 10, 2010 | 07:10 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
In open loop your gas mileage will suffer. IMO the induction system needs to be in closed loop.
Old Apr 10, 2010 | 07:25 PM
96GS#007's Avatar
96GS#007
With a big cam you can clean up the idle so that it doesn't smell. It's also easier to address cam surge at low rpms.
At WOT it really doesn't matter since the PCM ignores the O2 sensors anyway...well...if the fuel trims were >0% then it will add some amount of fuel to the base Power Enrichment value but you'd only notice it on a dyno or if you were consistent within a few hundredths at the track. Basically at WOT you're in Open Loop.
If you get it wrong with open loop, you can seriously fubar the engine, the cats, etc.
To Open Loop....
