How much power will these add
Old Apr 11, 2010 | 11:03 AM
M.J.L.'s Avatar
M.J.L.
St. Jude Donor '10-'11
Default How much power will these add
http://www.summitracing.com/parts/SLE-20002/
It CLAIMS 20 hp...How will this affect the RPM range?
Old Apr 11, 2010 | 11:09 AM
NMsharkracer's Avatar
NMsharkracer
From: Formerly from the Great White North but now residing in the Desert Southwest NM (The Land of Dis-Enchantment?)
To really achieve any meaningful HP increase, you'll also need a BigMouth intake or port your stock intake and plenum
Old Apr 11, 2010 | 12:10 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
After seeing a stock set 1st hand, it's hard to imagine that claim is true. I suspect any improvement was measured in conjunction with a large base (which also would improve flow).
The problem I see is the SLP tubes are BARELY bigger than stock tubes. And, the siamesing is so minor that neither change (vs stock) seems likely to significantly improve air flow. Plus, their castings are ROUGH (inside and out) -- which can't help air flow either!
As such, I went ALL the way thru my tubes expanding their size at least 10-15%. Plus, I added significant add'l siamesing.
If you're willing to buy a few inexpensive tools and "get busy", I think this option is well worth while. Otherwise, TPIS tubes or AS&M tubes would provide better results. (They are smooth, mandrel bent tubes that come sufficiently larger. Even though they're more expensive, the extra size is their from the get-go.)
One last tid-bit....The only person I know who did a back-to-back with AS&M vs SLP on an stock motor (with mild head porting) ran 2/10ths secs SLOWER after installing the SLPs. IOW, HP dropped 20 ponies with the SLPs -- as compared to the TPIS/AS&M stuff!
Old Apr 11, 2010 | 12:50 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Interesting !
Old Apr 11, 2010 | 01:55 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
To take advantage of these runners one must consider a cam, heads, ported intake base and then the runners will get that extra 20 HP.
Best to start with internals before messing with bolt-ons
Old Apr 11, 2010 | 02:01 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
You will get more benefit from aluminum UD pulleys at less than half the price.
Old Apr 11, 2010 | 08:42 PM
mbowers13's Avatar
mbowers13
From: https://www.facebook.com/groups/OrangeCorvettes/
Any time you see "depending on the application", the application usually isn't stock.
To How much power will these add
