Speed Bleeders
Old Mar 14, 2002 | 11:02 AM
Jim D's Avatar
Jim D
Default Speed Bleeders
Put speed bleeders on my 93 last night ,it took about 10 min. to bleed the brakes . These are the greatest thing since sliced bread , should have put them on sooner
Old Mar 14, 2002 | 11:12 AM
Arisa's Avatar
Arisa
Default Re: Speed Bleeders (Jim D)
Ain't that the truth. I love mine. Bleeding the system is oh so easy now.
Neal
Old Mar 14, 2002 | 12:33 PM
Hooked on Vettes's Avatar
Hooked on Vettes
Just a note/warning.
I installed two of them on the front calipers. About 3 weeks latter, the checkvalve on one of them started to leak.
I was coming to a stop and had no front brakes. The inside of the right front tire was coated with brake fluid.
I replaced the speed bleeder with another one. ( I purchased four). It appeared the leak was from the valve and not the
threads so keep an eye out for any leaks.
One thiing I don't like about them, is you may have to recoat the threads so it willl seal if you ever bleed the brakes
again. The sealant they sell is $10.00 for a small bottle. You recoat the threads and bake it in the oven for a couple of minutes.
Old Mar 14, 2002 | 04:49 PM
Zora's Avatar
Zora
Cruise-In I Veteran
Cruise-In II Veteran
Got a set on mine......works like a Charm. :yesnod:
Old Mar 14, 2002 | 05:11 PM
VMAX451's Avatar
VMAX451
Jim,
Where did you get them from? I keep meaning to get a set and will do it now that you reminded me.
Old Mar 14, 2002 | 06:27 PM
86VetteBill's Avatar
86VetteBill
Default Re: Speed Bleeders (Vince Ivanc)
http://www.speedbleeder.com/
Old Mar 14, 2002 | 07:10 PM
VMAX451's Avatar
VMAX451
Excellent, thanks! :cheers:
Old Mar 14, 2002 | 07:13 PM
VMAX451's Avatar
VMAX451
Default Re: Speed Bleeders (Hooked on Vettes)
Huh, I would think that when tightened down, the fluid would never be able to even get to the check valve, just like with the regular nipples. :confused:
Old Mar 14, 2002 | 11:18 PM
Bill Reid's Avatar
Bill Reid
:yesnod:
To Speed Bleeders
