Violent Shake
Old Apr 11, 2010 | 08:04 PM
FlyUSAF2002's Avatar
FlyUSAF2002
Default Violent Shake
Hi All -
1992 with 39,000 miles.
Driving today - just cruising at about 40mph with the top off. I hit a little bump and boom!!! - The car started shaking back and forth violently - steering wheel jerking back and forth in my hands. It continued like this for about 2 seconds and I hit the brakes hard thinking I'd done major damage... The jerking stopped and didn't happen again all day. I took a look for a loose rod on the front suspension - at a glance everything seems in order.
What do you think? (Note - it shook so violently, I'm surprised I didn't break the rear window...)
Andy
Old Apr 12, 2010 | 02:26 PM
Frizlefrak's Avatar
Frizlefrak
Jack one side of the car, grasp the tire at the 9 and 3 oclock positions, and try to move it. Then try the 12 and 6 posiitions. Any movement? Do this front and rear, both sides. I'm looking for a bad wheel bearing and / or tie rod end.
Next visually inspect all suspension bushings for wear, rot, etc. Replace anything questionable. Also visually inspect ball joints for wear and damage.
Now...you mentioned it's a 92 with 39K. How old are the tires? Check the date code on the sidewall.....often low mile cars of this age have tires that are dry rotted or hard as a brick.
Check all that out and report back.
Old Apr 12, 2010 | 02:44 PM
CaminoSS's Avatar
CaminoSS
Old Apr 12, 2010 | 07:16 PM
Weav's Vet's Avatar
Weav's Vet
Several older threads on this.
Mine dose it too or did..... I just replaced my tie rod ends front and rear. I can't believe what a difference it made in the handling of the car! Soon I'll try the top off again and see it it helped that shake. I do have one of those braces that hold the back glass open slightly. It helped a lot with the shimmy when the top was off.
Old Apr 12, 2010 | 07:19 PM
car5car's Avatar
car5car
To check lower ball joints you have to jack control arm, get a manual!
I bought 2 manuf. manuals yesterday for $40 and am very happy! Guy was selling them on Ebay, he lived 1 mile from me! I just showed up at his house. He bought all books from bankrupt GM dealer.
To Violent Shake
