idle setting procedure on L98 TPI
Old Mar 14, 2002 | 01:44 PM
corvette90's Avatar
corvette90
Default idle setting procedure on L98 TPI
Hi all,
i installed an airfoil on my 90 L98, cause i got it for free, and now sometimes idle is too low, sometimes, especially, when climate compressor engages, it dies..otehrwise it ran really fine, and pull strong...
what i want to know..
have anybody of you the procedure to set idle?
i have a description, that have to do with the IAC, the ALDL, aso..
do you agree?
any answers would be nice
Thanks :cheers:
Old Mar 14, 2002 | 01:47 PM
vader86's Avatar
vader86
Default Re: idle setting procedure on L98 TPI (corvette90)
set the TPS voltage to .57 VDC i believe, disassemble and clean the IAC
Old Mar 14, 2002 | 01:57 PM
Greg Johnson's Avatar
Greg Johnson
Default Re: idle setting procedure on L98 TPI (vader86)
Sometimes your butterflies can be closed too tight and not letting enough air in. you'll know this if they're sticking in the closed position. There's a torx screw on the driver's side, top of the throttle body. It will adjust the opening of the butterflies.
Greg
Old Mar 14, 2002 | 02:08 PM
Bluevette85's Avatar
Bluevette85
See Tech Tip below but you may need to set the minimum idle slightly higher (450-500).
www.corvetteforum.com/techtips/viewsubtopic.php?SubTopicID=55&TopicID=2
Old Mar 14, 2002 | 02:57 PM
corvette90's Avatar
corvette90
ok...but is the procedure on a 90 the same??
thanks..
Old Mar 14, 2002 | 03:04 PM
Bluevette85
Setting the idle should be the same but you may not have an adjustable TPS.
KYVette90's Avatar
KYVette90
Jumper pins a & b. Unplug timing connector under hood by the ecm. Turn ignition on but do not start car. Wait 30 - 40 seconds. Unplug IAC connector. Unjumper pins A&b and start car. Keep it running with the gas and adjust idle to about 450 to 550 rpm. Turn car off. Plug IAC back in plug the timing connector back up and start car again. It probably won't run right the first time you restart it so turn it off and restart one more time. If your factory tach is off you will have a hard time getting it set right. My factory tach was off by 650 rpms at idle. I always thought I had a high idle problem until I installed an aftermarket tach.
Old Mar 14, 2002 | 03:20 PM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
Default Re: idle setting procedure on L98 TPI (KYVette90)
:yesnod: That is a step that is missing from https://www.corvetteforum.com/techti...D=55&TopicID=2 With the timing connector unplugged you should get a code for it. I just unplug the battery for 10 seconds to clear it b4 I start it back up. I'm doing this today b/c I took out the airfoil and it messed up my idle setting.
Old Mar 14, 2002 | 03:41 PM
corvette90's Avatar
corvette90
Default Re: idle setting procedure on L98 TPI (War Machine)
will i need to turn the stop screw in the TB, or does it only go with the throttle blades?
Old Mar 14, 2002 | 03:52 PM
Greg Johnson
You shouldn't need to turn the stop screw because it is only for the TB butterfly blades.
Greg
Old Mar 14, 2002 | 03:56 PM
corvette90's Avatar
corvette90
Default Re: idle setting procedure on L98 TPI (Greg Johnson)
ok..so that means, the stop screw have nothing to do with idle speed, and the odle is only controlled by the IAC counts..
Old Mar 14, 2002 | 03:58 PM
Greg Johnson
90,
Take the air duct off the TB and start the engine. Check the air flow into the TB. If it seems to be sucking only through the little hole at the base of the airfoil, THEN you adjust the set screw on the TB so the butterflies open slightly. Sorry I didn't clarify! It's got nothing to do with the rest of the idle adjustment as far as I know.
Greg
Old Mar 14, 2002 | 06:42 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
You set the minimum air adjustment using the little set screw on the TB, this is how you set to say 500-550 RPM. Once set using the proceedure in the tech tips, do not touch the screw again (unless you go through the whole proceedure). I was able to set mine with the timing wire connected, if you have a hard time getting it to idle you can disconnect the wire.
Pete
Old Mar 14, 2002 | 08:35 PM
Aggravated4life's Avatar
Aggravated4life
Default Re: idle setting procedure on L98 TPI (PeteL)
Pete's right and BTW you should never touch the TB screw unless you were going to readjust the minimum air speed.
I find it interesting you installed the air foil and now it wont idle right at times.I think you may have reused the gasket for the TB cover and if so replace it with a new one.
While a vacuum leak can sometimes cause a higher idle,it wont suprise me if thats causing the idle speed to drop out.
The TPS on certain years isnt adjustable either.
In other words,remove the air foil and see if the problem goes away.Do not reuse the old TB cover gasket either.
Old Mar 14, 2002 | 08:50 PM
KYVette90's Avatar
KYVette90
Default Re: idle setting procedure on L98 TPI (Bill's86Coupe)
I think sometimes, the problem with the airfoil affecting the idle is caused by the airfoil restricting air flow through the IAC air passage. The airfoils bolt right over the hole where the IAC air flows through. If it is really messing with your idle you might want to just remove it completely.
To idle setting procedure on L98 TPI
