1986 NGK plug type
Old Apr 13, 2010 | 03:38 PM
charv66's Avatar
charv66
Default 1986 NGK plug type
Reputable (until further notice) local parts store sold me eight
NGK UR5/2771 plugs today for my 1986 C4. I got half of them in then I noticed they are somewhat shorter than the ones that were in there already (Autolite 24).
All they had in stock was NGK. Is this the right NGK type?
-Vince
Old Apr 13, 2010 | 03:55 PM
toptechx6's Avatar
toptechx6
Here is a link to NGK's website, you can check for yourself.
http://www.ngksparkplugs.com/part_fi...uv/default.asp
Old Apr 13, 2010 | 04:42 PM
charv66's Avatar
charv66
Thanks. Were all 1986 aluminum heads?
Old Apr 13, 2010 | 05:23 PM
azrocketman's Avatar
azrocketman
No. All convertibles and late '86 (maybe last 7000 cars) had aluminum heads.
Steve
Old Apr 13, 2010 | 05:24 PM
toptechx6's Avatar
toptechx6
The Black Book says all convertibles got aluminum heads and the last 8594 coupes. Easy enough to tell, try a magnet on them.
Old Apr 13, 2010 | 05:33 PM
azrocketman
Even easier to tell (if stock): Iron heads have valve cover bolts on the perimeter and aluminum heads have valve cover bolts down the middle.
Steve
Old Apr 13, 2010 | 05:36 PM
charv66's Avatar
charv66
They aren't magnetic - thanks for the tip, my VIN is 1G1YY078XG5110177. Would this be considered a late production number?
Old Apr 13, 2010 | 05:45 PM
samsonb's Avatar
samsonb
Just go look and see if the valve covers have perimeter bolts or center bolts. That will tell you for sure.
Perimeter bolts = Iron heads
Center bolts = Aluminum heads
Old Apr 13, 2010 | 05:59 PM
toptechx6's Avatar
toptechx6
There you go, even easier in case you have bad magnet! The VIN looks to be an early car, my Black Book shows 35,109 total production, 27, 794 coupes and 7315 ragtops.
Old Apr 13, 2010 | 06:17 PM
charv66's Avatar
charv66
Ok aluminum it is! No magnetic attraction + has center bolts on the valve covers.
Eight new NGK FR4's going on. They are slightly longer than the old Autolite 24s that were in there but perhaps they were the wrong type to begin with.
Old Apr 13, 2010 | 06:21 PM
toptechx6's Avatar
toptechx6
So much for the accuracy of the Black Book unless a previous owner replaced the heads? Anyway glad you figured out which plugs were correct.
Old Apr 13, 2010 | 06:23 PM
charv66's Avatar
charv66
I'm always a little nervous putting in longer plugs though!
Old Apr 13, 2010 | 07:16 PM
toptechx6's Avatar
toptechx6
My GM parts reference shows the original AC Delco plug to be FR3LS, and according to this crossover chart the FR4's should be correct.
http://www.clubplug.net/cross.html
Old Apr 13, 2010 | 07:33 PM
charv66's Avatar
charv66
[QUOTE=toptechx6;1573749490]My GM parts reference shows the original AC Delco plug to be FR3LS, and according to this crossover chart the FR4's should be correct.
http://www.clubplug.net/cross.html[/QUOTE
Thanks everyone.
Old Apr 13, 2010 | 07:41 PM
Joe C's Avatar
Joe C
for my 90, i presently have ACDelco FR5LS (in the car when i bought it) i have a set of NGK replacements, FR4GP's. the NGK's are slightly longer, but barely noticeable...
To 1986 NGK plug type
