Bought a 94 convertible
Old Apr 13, 2010 | 09:15 PM
ChrisLT1conv's Avatar
ChrisLT1conv
Default Bought a 94 convertible
I bought a 1994 convertible vette a few months ago and am very pleased with it. What I was writing about is I noticed it felt like a plug was a little weak and when I got to looking at the wires this thing still has the factory wires and plugs at 95K. I am going to change them immediatly. I just wanted to post this because I was amazed the thing is still running good with those wires and plugs.
P.S. Yes it did have a new air filter in it and yes I have done changed the oil and put sythetic back in it. I know I need to go ahead and flush the coolant system to be on the safe side and I figure I will go ahead and order an air foil for it
P.S.S. Where can I find the rear axle ratio for the convertible? Mine is an automatic.
Old Apr 14, 2010 | 06:50 AM
Red-Lt1's Avatar
Red-Lt1
Look at the RPO codes for the axle ratio
Old Apr 14, 2010 | 07:35 AM
runner140*'s Avatar
runner140*
Also, you might want to hit the grease fittings, flush/change the diff. oil, trans fluid, power steering fluid and brake fluid. Check all the hoses and the belt.
I'm sure others will chime in with additional areas to check but its a good start.
And welcome aboard.
Old Apr 14, 2010 | 08:02 AM
ks5shooter's Avatar
ks5shooter
St. Jude Donor '10-'11-'12-'13
Welcome this forum will be the best tool in your toolbox
Old Apr 14, 2010 | 01:29 PM
Camelotian's Avatar
Camelotian
I have the same year. Got it last August and love it. I still have to change trany, diff, brake, & P/S fluid.
Old Apr 14, 2010 | 02:27 PM
ChrisLT1conv
Where is the rpo code located?
Also; thanks for all the welcoms guys.
Old Apr 14, 2010 | 02:29 PM
frenchyoliver's Avatar
frenchyoliver
central console
Old Apr 14, 2010 | 02:44 PM
CAJUN C4's Avatar
CAJUN C4
Definatly...a wealth of knowlege here.
And Welcome to "The" Corvette Forum.
Old Apr 14, 2010 | 03:39 PM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Welcome to the form and could you please fill out your sig
Old Apr 14, 2010 | 05:31 PM
car5car's Avatar
car5car
Congrats! I bought 94 about 2 weeks ago. So far: both lower ball joints, both outer tire rods, inner tire rod, cracked right exhaust man., vac. check valve, broken vac hose to climate control, both leaking AC valves. Intermittent right window problem, antenna mast, tr. pan gasket, oil pan/r. main seal(?) leak, bad rack and pinion adjustment, bought 2 front tires.
Good luck!
first of all check front suspension. and fluids.
Spark plugs are platinum from factory and have to be replaced at 100K miles.
Old Apr 17, 2010 | 05:31 PM
ChrisLT1conv
Originally Posted by frenchyoliver
central console
Sorry but there is absolutely nothing in my cetral console. No plaques, stickers, or anything.
Old Apr 17, 2010 | 08:09 PM
desertmike1's Avatar
desertmike1
congratulations Chris....welcome
Old Apr 18, 2010 | 12:50 PM
F&Yb0dluvr's Avatar
F&Yb0dluvr
most C4 verts got the 2.59(GM1) axle
pray you see a "G92" and are lucky to have the 3.07's.
Old Apr 18, 2010 | 03:20 PM
The Green Rocket's Avatar
The Green Rocket
On your '94 convertible you may find the RPO codes sticker not in your center console, but on the lid for the rear storage compartment behind the passenger seat. Code G92 for the performance axle.
Thomas
Old Apr 21, 2010 | 08:56 PM
ChrisLT1conv
Thanks for the congrats guys and thankyou for the info
Old Apr 21, 2010 | 10:09 PM
94vettelover2's Avatar
94vettelover2
Congrats on the purchase-94s are awesome as I have one too.Car dealer with VIN.They will be able to tell you your axle ratio.They told me mine by VIN(3.07It your car an automatic?Welcome to the forum
To Bought a 94 convertible
