Miniram help
Old Apr 15, 2010 | 01:14 AM
mavidatt's Avatar
mavidatt
Default Miniram help
Im planning on going to brodix 180 aluminum heads and the hotcam and then topping it off with a miniram on zz4 crate engine in my 89 vette. Few questions, will stock throttle body from stock intake work with miniram, also what about fuel injectors from stock motor, should they be ok? I know i will need a tune for the setup. Also is there any suggestions with links to better cam for the miniram setup. Thanks!
Old Apr 15, 2010 | 07:51 AM
mseven's Avatar
mseven
A stock TB will work fine. There are other cams, but the hot cam is a good cam that makes decent power and has nice drive-ability..
Old Apr 15, 2010 | 07:00 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
If you have the original 22 lb injectors they should be fine if working correctly. You might look at something like the LPE 219 just for grins.
Old Apr 15, 2010 | 07:41 PM
floridamale's Avatar
floridamale
If your injector are orignal I would have them at least check before I put them back in. Or you could just contact Jon @ FIC and get Bosch lll'3 for under 200 and be done with it
Old Apr 15, 2010 | 07:50 PM
ch@0s's Avatar
ch@0s
If you haven't already bought the cam there are better options as stated.
Old Apr 15, 2010 | 10:25 PM
JackDidley's Avatar
JackDidley
That sounds like a winning combination.
To Miniram help
