vacuum test
Old Apr 16, 2010 | 10:17 AM
OptiPrime's Avatar
OptiPrime
Default vacuum test
Hi,
Using a meter where is the best place to gauge the vaccum pressure and what is normal for an LT1?
I replaced the brake booster and got her all back together. Now the engine won't idle down. It idles at about 1500. I let it run for a while but the idle never came down. Can't remeber if this happend the last time I parked her; its been about 4 weeks.
Double checked all the hoses and connections that were reconnected after the booster install. All seemed fine.
Brake still are shot. I bled all 5 points as defined in the SM with a manual bleeder. I am ordering a reman MC.
I am wondering if the high idle could be caused by a vacuum leak. This would affect the braking also.
Any other idea why she would idle so high?
Also, where is a good place to order an MC.
Thanks!!
