Hey I am installing a new fuel filter, on my 91 L98 vette, and I was wondering where the filter is located? If any one can tell me that would be great. Thanks,
Along the frame rail on the passenger side of the car. You get to it from underneath the car. If you follow the fuel lines running along the edge of the car towards the front you will see it tucked up there.
Do not forget to depressurize the fuel system before doing this. :)
1. Pull the fuel pump fuse.
2. Take the cap off of your gas tank.
3. Start the car and let it run until it stalls.
4. Try starting it again, if it does let it stall.
5. Repeat 4 until it won't start.
If you let the car sit overnight it will be easier, if you just pulled in off of the street it might take a little while.
