opti replacement
Old Apr 17, 2010 | 12:48 PM
Hanny93's Avatar
Hanny93
Default opti replacement
I am thinking of replacing the opti in my 93 vette.
Are the opti 1's getting hard to find and which one do you suggest I get?
Thanks for the help.
Old Apr 17, 2010 | 12:53 PM
CAJUN C4's Avatar
CAJUN C4
I understand the MSD is one of the better ones.Accel is not too good.GM OEM is good
Old Apr 17, 2010 | 01:23 PM
skybolt31's Avatar
skybolt31
If you do an archive search on this forum and many others, you will find that there is not consensus on which opti is best. Having said that, I think that most people would stay with either an OEM, an MSD or a Dynaspark. the MSD and Dynaspark are both beautifully engineered and machined pieces of workmanship however neither has proven to be any more durable than the OEM units. Many people have had troubles with any of the various "low cost" replacements available.
Now you have the first generation "unvented" unit which can be upgraded to the vented type. In my opinion, I think this is a good idea and worth doing. I only base this on doing many hours of archive searches and not on years of actual testing or personal experience. There are several ways to do this upgrade, one is to change your timing chain cover, etc to accept the new style opti, one is to add vents to an unvented OEM unit, the third way is to get an MSD or Dynaspark unit which will bolt on to your engine and have the vent provisions in place. I would probably go with an MSD or Dynaspark unit if it were me. I have a 95, which is vented, so when I changed my waterpump, I used put in a new OEM unit.
To opti replacement
