The plug wires are original, with only 23k miles on them, BUT they are on an 1988 and thus 22 years old. I am having no known ignition issues. Should I leave them be or change them out with new AC-Delcos just on principle (age).
Start it some damp night with the hood open in the dark. If they were failing you can see arcing around the wires. You would need to unplug the underhood lights if you haven't already. I just leave mine unplugged b/c I'm always messing around under the hood and my battery would go dead.
If they were failing you would have missing in damp weather. But if they are ugly, then I would vote replace anyway!
Not an expensive deal and you will have peace of mind. I just changed the ones on my 86, one was badly cracked but they don't sell them individualy. I used Bosch wires, took about 30 minutes. Do one at a time.
Someone said you can mist (just a little of course) a little water in the pitch black with the engine running and look for a light show.
I think I will try that Monday night if I remember!
If you dont have problems and there is no "light show" I would just leave it...
old plug wires can work perfect...until you change the plugs. twisting, pulling on them can destroy what little electrical and mechanical integrity remained. and they don't necessarily have to arc and produce a "light show"; they can break internally and either go dead or have their internal resistance raised to where the plugs don't fire properly.
