1991 aldl
Old Apr 18, 2010 | 04:59 PM
SteelBlue91's Avatar
SteelBlue91
Default 1991 aldl
OK, I got myself a usb cable from aldlcable and I sat down to get it working so I can get some scans. After a few hours, I feel like a 2nd grader in a calculus class!
I have the cable installed and setup. If I plug the thing in with a hyperterminal (puTTY) window open, I get some garbled data. Is it supposed to look like that? I assumed this was correct because all of the software programs that came with the cable need a ecm definition, which I assume is what "decodes" the info.
I tried all of the programs that I could get to run on my Vista laptop, and none seem to list my ecm (1227727, right?). Is there a definition for winaldl or tunerpro for this ecm? Tunerpro's site lists some under that number, but the engines are WAY off (like v6 or turbo motors).
Am I missing something? I feel like the answer is obvious and I just can't find the big red button... All I want to do is the basic scan to look for anything suspicious.
Old Apr 18, 2010 | 09:27 PM
ch@0s's Avatar
ch@0s
here is TTS data master it's what I use, free trial then u buy it.
http://www.ttspowersystems.com/softw...M-8D-setup.exe
Old Apr 18, 2010 | 09:48 PM
rodj's Avatar
rodj
Originally Posted by SteelBlue91
none seem to list my ecm (1227727, right?). Am I missing something?.
TunerPro $8D
Same def file as used for '730 ECM ( Same ECM ; different case. Vette is weatherproof to mount under hood)
http://www.tunerpro.net/downloadBinDefs.htm
Download both the .ecu and ads files
NB; the weatherproof '727 ECM was used in lots of other GM products which is why you are seeing turbo files
Come back when you have the files; when using a USB cable there are some tweaks to be done to set it up .Sometimes laptop will not auto detect cable and you manually have to set the Comms ports
Old Apr 19, 2010 | 05:23 PM
SteelBlue91
Cool, thanks for the info. I think the cable is setup and talking correctly, as I can see some data coming across in a raw terminal.
I had not tried TTS due to the price of the 21st session , but it looks very nice. I will at least load it up and see.
As for the tunerpro, I have a hypertech pcm chip; is that ecu bin going to match what I have? I figured all I needed was the stream definition file for getting the scan data.
Unfortunately I probably won't get a chance to work on it until tomorrow. I will post back with the results.
Edit: Got a few minutes to try out tunerpro with the 730 file and it appears to work like a champ! With my small time window I just tried it not running and played with the gas pedal to check the tps and it appears to work perfectly. Thanks!
Old Apr 20, 2010 | 09:37 AM
ch@0s's Avatar
ch@0s
I haven't bought it yet.. I don't think I will need to
To 1991 aldl
