Tach reading problem---tach filter or cluster??
Old Apr 19, 2010 | 02:59 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Tach reading problem---tach filter or cluster??
Tonight was the first time at highway speeds since the motor rebuild and I noticed that at 64mph the tach readings were high and varying qite a bit, while at 55mph they were pretty steady and looked normal.
I ran the Auto X-Ray in Monitor mode to verify that the ECM was indeed seeing correct RPMs, i.e. 1600rpm at 64mph.
Any experience with this one??
Old Apr 19, 2010 | 08:09 PM
65Z01's Avatar
65Z01
Anyone with input on this one, please...
Old Apr 19, 2010 | 08:19 PM
miscstudent's Avatar
miscstudent
Actually just did some research into this. What most people have found is that it is the tachometer filter is going bad. Replacements are $35 from Corvette Central
Old Apr 19, 2010 | 09:10 PM
WW7's Avatar
WW7
If your scanner is saying the right rpm and the gauge isn't, it sounds like your tach filter...Go here and get the non GM filter for $22.00 , he makes them himself and they work great.. Plus shipping is just $4.00.. Ive had this same one on my 89 for over 3 years with no problem..WW
http://rodneydickman.com/catalog/pro...roducts_id=265
Old Apr 19, 2010 | 11:11 PM
sceptor98's Avatar
sceptor98
I'm having the same problem also. My tach gauges goes crazy at anything above 55mph but if im parked or driving below 50mph they measure normally.
Old Apr 20, 2010 | 05:21 PM
65Z01's Avatar
65Z01
Yes, it was a tach filter issue; thanks for the replies...
To Tach reading problem---tach filter or cluster??
