Have codes h31, h33, h35, h37 HELP
Old Apr 19, 2010 | 05:28 PM
bacord's Avatar
bacord
Default Have codes h31, h33, h35, h37 HELP
The sys light on dash started flashing on 95 lt1 auto, pulled the codes and got h31,h33,h35, and h37. I dont see the 31,35 or 37 codes on my list. code h35 is "MAP sensor signal voltage was too low (high vacuum) when engine speed was under 700 RPM, or when TPS was greater than 20% with an engine speed above 700 RPM."
Old Apr 19, 2010 | 06:00 PM
SunCr's Avatar
SunCr
The "H" means they're History and no longer present so it's meaningless.
Clear them and see if any come back as Current or "C".
Old Apr 19, 2010 | 08:27 PM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
This will happen if your battery voltage was low.
Old Jul 12, 2019 | 05:05 PM
Marcus123's Avatar
Marcus123
Default Reply
I haven't seen that anywhere thank you. Also how to you clear the codes
Old Jul 13, 2019 | 10:11 AM
fredk's Avatar
fredk
Disconnect black battery cable wait 20 seconds then reconnect. This will clear the codes.
To Have codes h31, h33, h35, h37 HELP
