Engine light on a no codes
Old Apr 19, 2010 | 10:35 PM
kjr2492's Avatar
kjr2492
Default Engine light on a no codes
I tried to check the engine light code because it will be on for awhile and then go off and the car runs good and overdrive works great. I hooked up scanner and no codes,. I did the paper clip and the light will not blink. Could this be a bad ECM? If so how could I try to resest it first before buying one?
Old Apr 19, 2010 | 10:48 PM
bigkat's Avatar
bigkat
Default Engine Light
For what it is worth I have a 1990 which throws no codes but the service engine light comes on if I am traveling the freeway for about 15-20 miles at around 70 mph. The previous owner called me two weeks after I had bought the car to mention it and also told me to check his receipts from the dealership for the 3 time he brought it in to have it checked. Verdict each time was either they could not find a code or they could not duplicate. I am sure someone knows more about this than me but I think it is some sensor on the exhaust that just does not pick up a signal during constant speed
Old Apr 19, 2010 | 10:50 PM
kjr2492's Avatar
kjr2492
I forgot to put that the car runs bad and the overdrive doesnt work when the engine light is on. When it goes off the car runs good and the trans runs good
To Engine light on a no codes
