LT4 Starter Issue
Old Apr 21, 2010 | 07:23 PM
RUU's Avatar
RUU
Default LT4 Starter Issue
Lately, when I try to start my '96 in the morning, I can hear the starter spin, but it doesn't engage the flywheel on the 1st few attempts. Voltage is 12.4 volts (new battery last year). Eventually it will engage, but seems to be taking increasingly more attempts. Just want to verify it's likely the starter & I'm not overlooking something else.
Thanks.
Old Apr 21, 2010 | 07:34 PM
CAJUN C4's Avatar
CAJUN C4
Sounds like either the Solenoid or Bendix Spring going out.
Probably better change out the starter.
How many mile on it?
Old Apr 21, 2010 | 08:52 PM
RUU's Avatar
RUU
Thanks for the reply. The car has 80K on it. I've had it for 2 years, now and there was no record of the starter being changed in the service records provided by the PO, so it may well be the original.
Old Apr 21, 2010 | 10:06 PM
SJW's Avatar
SJW
The starter's drive gear that engages the ring gear on the flywheel is coupled to the starter's armature shaft via an overrunning clutch. Based upon your description, there can be little doubt that this clutch is failing. You'll probably see the problem worsen until it is fixed. The simplest fix is to either replace the starter or have it rebuilt by a reputable rebuilder.
The overrunning clutch allows the drive gear to decouple (spin freely) on the armature shaft if the ignition switch is held in the Start position after the engine has started. This prevents over-revving and destruction of the starter armature.
Live well,
SJW
Old Apr 25, 2010 | 10:30 PM
RUU's Avatar
RUU
Just to follow up, I ordered a new (reman) starter from NAPA (one of two places that could get me one next day) on Thursday. Of course, the vette decided to be on it's best behavior that day! Too late, Saturday I was able to wrestle the old one out & the new in. Works perfect - even when the volts drop to 12.
As it turns out, the starter I took out was a replacement as indicated by the tag still attached to it which said "Remove and attach to customer invoice." Shouldn't be surprising though, any part that lives that close to the catalytic converter isn't destined to have that long a life.
To LT4 Starter Issue
