Head Bolts --Reusable or not
Old Apr 23, 2010 | 07:08 PM
DarkBlue88's Avatar
DarkBlue88
From: Charlotte NC, behind someone going 10 under the speed limit
Originally Posted by Tom400CFI
I agree. Reading some of the posts in this thread, I also think some people don't understand the difference.
The stock bolts are not TTY. The "torque precedure" for tightening the bolts, does not a TTY bolt, make.
If the final pass isn't in degrees of rotation, , but in ft lbs, that SHOULD indicate they are not TTY.
Old Apr 23, 2010 | 10:25 PM
MK 82's Avatar
MK 82
See what I mean. Another one emphatically on the non TTY side. The Gold Std is measuring the stretch of a bolt. When that is not possible, you are left with straight torque or initial torque and final angle rotation.
I should have started a poll.
Old Apr 23, 2010 | 11:00 PM
cv67's Avatar
cv67
St. Jude Donor '05
I know these are TTY LT1 Fbody pressure plate bolts one time use
Dont know if appearance by itself determines tty have seen different images of necked down and non.
Old Apr 24, 2010 | 11:57 AM
MK 82's Avatar
MK 82
What other bolts on an LTX are allegedly TTY?
Flywheel?
Pressure Plate?
Rods?
Main Bearings?
Old Apr 25, 2010 | 08:10 AM
mashinter's Avatar
mashinter
I'm guessing that the angle method is an attempt to attain a certain stretch in the bolt. The pitch of the fastener is known; calculate stretch based on that, you get an angular displacement. Since most of the torque you apply goes into friction at the head of the bolt, this is an attempt to reduce friction as a variable?
Old Apr 25, 2010 | 06:01 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
That is correct.
Old Apr 25, 2010 | 07:52 PM
MK 82's Avatar
MK 82
Go to the head of the class.
Now- what other bolts are TTY?
Old Apr 25, 2010 | 09:03 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Originally Posted by 96GS#007
They're TTY. Toss 'em and spend the $60 on ARP.
Old Apr 25, 2010 | 09:42 PM
mike100's Avatar
mike100
Here are the bolts in question. They do neck down a bit about and inch below the head.
I think the only definitive way to know if they are TTY is to compare the length to a new one. TTY bolts are designed to stretch beyond the elastic range into the plastic range. That means they don't return to their original lengths when loosened.
Those look like every other small block head bolt that I've ever seen previous..notice no shaft diameter variation or larger/smaller rolled thread section. The neck step at the head is the same for pretty much all head bolts made in the last 40 years for the sbc as far as I have seen.
you could probably torque those to 65 lb/ft and they would pronbably be fine...but anyways..I usually bought ARB ones for anything that was higher than stock hp.
Old Apr 25, 2010 | 10:05 PM
96GS#007's Avatar
96GS#007
From the book..."How to Rebuild Small-Block Chevy LT1/LT4 Engines" "Step-by-Step Rebuild to Factory Specifications. Covers 1992-1997 GM Cars and Trucks" by Mike Mavrigian on page 21....
"Since the SB2 engines [ie Small Block 2nd Generation, which the LT1/4 are] use TTY (torque-to-yield/torque-angle) cylinder head bolts, these original bolts will not be reused during final assembly."
Hope this ends the debate. It's in the FSM as well, I just haven't had a chance to go digging thru it again.
Old Apr 25, 2010 | 10:34 PM
MK 82's Avatar
MK 82
I read that too. It hardly ends the debate. It's another man's opinion. How much more or less weight do we give to it?
I still can't find it in the FSM.
Old Apr 25, 2010 | 10:35 PM
MK 82's Avatar
MK 82
Originally Posted by kenv
Based on what?
Old Apr 25, 2010 | 11:32 PM
  #33
96GS#007's Avatar
96GS#007
Whatever.
I'm tired of this thread. Good luck with your search for knowledge
Old Apr 26, 2010 | 09:11 AM
  #34
mashinter's Avatar
mashinter
It's not in the FSM for my '92 LT1. If the bolts are TTY, there should be warnings that the fasteners are to be discarded.
If you look at the '92 LT5 section, page 6A2B-31, you'll find a warning to use NEW main bearing bolts whenever they are removed for service. Same for con rod bolts.
Old Apr 26, 2010 | 10:51 AM
  #35
MK 82's Avatar
MK 82
Whatever.
Come on Jim! That's all it is. A search for knowledge. Maybe someone can ask Gordon.
Old Apr 26, 2010 | 01:48 PM
  #36
JAKE's Avatar
JAKE
It boils down to what source you believe and have your confidence in.
When I compare one source with another I seem to regularly find disgreements.
Take for the example the specs shown in the HAYNES "CHEVROLET CAMARO PONTIAC FIREBIRD Automotive Repair Manual" #24017 where it lists on page 2D-4, LT1 CRANKSHAFT AND CONNECTING RODS as:
Connecting Rod Journal Diameter ; 2.0978 to 2.0998 inches
Bearing oil clearance .0008 to .0022 inch
Crankshaft Main Bearing Journal Diameter: 2.4988 to 2.4998 inches
Oil Bearing Clearance: .001 to .003 inches
Now when you check the 1996 Corvette Factor Service Manual and page 6-15:
Crankshaft (Main) Journal Diameter #1 thru #5 2.4485 to 2.4491 inches
Main Bearing Oil Clearance:
#1, #2, ## and #4: .0009 to .0020 inches
#5 .0010 to .0021 inches DIFFERING FROM HAYNES
Connecting Rod Journal Diameter 2.0978 to 2.0998 inches (which are the same in HAYNES BUT bearing clearance in the FSM is listed as .0013 to .0035 inches WHICH DIFFERS FROM HAYNES which listed .0008 to .0022 inches
I hang my belief on GM's specs. On which do you believe?
Jake
Old Apr 26, 2010 | 09:58 PM
  #37
93 ragtop's Avatar
93 ragtop
I have a haynes manual (24041) It states that on 92-95 torque to 65ft lbs. On a 96 it says 22 ft lbs, then an additional 67 degrees on short bolts and 80 degrees on med, and long bolts.
I do not know for sure if the 96 is a TTY or not, but knowing it is the same motor, I would suspect it. I cant imagine using a different torque sequence on the 96 unless it was TTY bolts.
FWIW I reused the bolts on mine when I switched heads several years back. Never had any problems with the head bolts, gaskets etc.
Old Apr 26, 2010 | 10:34 PM
  #38
black85's Avatar
black85
I've done many Volvo and a couple Porsche turbo heads with torque to angle specs. Those manuals state to measure the bolts to ensure they are still within spec. They do stretch, and that is ok within spec. I have always been able to reuse the bolts or find other used bolts within spec. I'm very surprised that GM doesn't publish such a spec.
Old Apr 27, 2010 | 11:46 AM
  #39
MK 82's Avatar
MK 82
All bolts stretch. TTY bolts do not return to their original lengths. I can find nothing in the 96 FSM that indicates that any bolts anywhere on the car are TTY and therefore not reuseable.
I started this thread as a search for info. You will find this debate all over the net. It is a debate but folks let their emotions get away from them. Nowhere have I found concrete proof that the head bolts are TTY. I plan to put new bolts in mine to be safe.
I suggest that anyone interested in this issue spend some time on ARP's site learning what is involved in trying to properly tighten a bolt. I learned a lot.
Here is the catalog. Start on page 27.
Eddie
