Water connection on 89
Old Apr 22, 2010 | 11:52 AM
Redvette_22's Avatar
Redvette_22
Default Water connection on 89
What is the reason GM put the water connection at the right rear of the TPI intake manifold of the 89 Vette? I want to do the LT-1 intake mod but it will not have that attachment so I'd like to know if it will cause any harm or problems? I know some other Vettes have had this intake manifold swap, but were any done on years that had this hose connection, and if so, what did you do about it??
Old Apr 22, 2010 | 01:16 PM
SpedRacr93's Avatar
SpedRacr93
When I did the LT1 intake on my 89, I just drilled and tapped the back of the LT1 intake and put these connectors in.
All they do is prevent air from getting trapped in the rear of the head. If you follow that hose, it just dumps back into the heater hose. You don't have to have them, but why not?
I run a Mini-Ram now and I just left them off.
Old Apr 22, 2010 | 02:03 PM
ch@0s's Avatar
ch@0s
What he said. I put a HSR on mine left them off.
Old Apr 22, 2010 | 08:25 PM
vetteoz's Avatar
vetteoz
Deleted the vent hole on my engines long ago with no ill effects
Old Apr 23, 2010 | 01:33 AM
89Corvette6spdFX3's Avatar
89Corvette6spdFX3
It's there for you to burn your arm on when adjusting spark plug wires or anything else after the car's been running! Seriously, many bad words came out of my mouth because of that stupid little tube!
Old Apr 23, 2010 | 12:43 PM
SunCr's Avatar
SunCr
But the real reason it's there is to supply a sufficient amount of coolant at the rear of the heads which on the Vette, uses a restriction to keep coolant there longer. There's no steam - or air - or anything else in that hose - or if there is, you Cooling system needs some attention. To eliminate it, you need to eliminate the restriction, which you can do by getting some F Body intake gaskets which doesn't use this setup.
Old Apr 23, 2010 | 01:21 PM
ch@0s's Avatar
ch@0s
I would just used a Felpro 1204/1205
To Water connection on 89
