Power steering repair
Old Apr 22, 2010 | 03:02 PM
choopes's Avatar
choopes
Default Power steering repair
A while back I changed the PS cooler on my 1993 coupe with an after market unit. Something I wish I had not done. It leaked at the hose connection, and now the pump foams white inside the resivior, and has all the symptoms of a bad pump. I want to change the pump, the hoses, and replace the after market cooler with what's supposed to go in there.I was reading on the forum that it's best to replace the hose with a shorter, right angle bent hose from a '95(part # 26042088). Hose would need to be re-routed. Has anyone with a 92-94 done this? How hard is it? Where exactly does the hose get re-routed? I wouldn't bother to ask but space is pretty limited.
Thanks!
