87 Corvette VATS question/problem
Old Apr 22, 2010 | 04:16 PM
ratortor's Avatar
ratortor
Default 87 Corvette VATS question/problem
I installed the Mid-America Vats bypass system (the one with 3 settings).
It seemed to work well for a while.
I set it on the middle setting all of the time which is supposed to keep the car in bypass.
However, on a few occasions, I get the no-crank situation..
Since I have a battery cutoff switch, I just use the cutoff and turn the
car on again, and it starts fine.
I was told that even though the VATS Bypass is installed, it works in conjunction with the VATS system and that I should replace the theft deterrent relay.
Does this sound correct?
Your help/comments always appreciated.
Bob T
Old Apr 22, 2010 | 05:05 PM
redrose's Avatar
redrose
that relay is the most common varts (rhymes with ____) fail component...good to replace it, best IMHO to bypass it...ez bypass at the relay is to use a snap-lock 'trailer lighting' wire connector (cut connector internal stop so both wires run thru)....IIRC the two wires on 87 are yellow and green/white wire, but you must verify before modding.
Old Apr 22, 2010 | 08:22 PM
vetteoz's Avatar
vetteoz
The bypass only takes out the requirement for the correct key to be seen.VATS module and its components are still in place and working ( or not as the case may be)
Taking out the starter relay as suggested by Redrose removes one more fail item.You still have the VATS injector cutoff as theft protection
Old Apr 22, 2010 | 09:32 PM
ratortor's Avatar
ratortor
Default Theft deterrent relay
Thanks for the picture and comments.
Where exactly is the relay....how do I get to it?
Old Apr 22, 2010 | 11:05 PM
jfb's Avatar
jfb
Not only the starter enable relay is in the crank circuit, a more common failure is the clutch safety switch (gear selector switch at the base of the gear shift if automatic). Next time it won't crank, unplug the clutch safety switch and jump the wiring harness socket and try a crank. You must have 12 v on the jumper in crank position. You can test your starter by jumping 12v to the jumper, the starter should crank.
Old Apr 23, 2010 | 06:40 AM
ratortor's Avatar
ratortor
Default more
I forgot to mention that the car is an automatic..........
Old Feb 25, 2014 | 05:24 PM
jerrycffy's Avatar
jerrycffy
8th Gear
Lost keys to 87 vette. How do I eliminate the vats system?
Old Feb 25, 2014 | 05:33 PM
MrWillys's Avatar
MrWillys
You can reprogram your memcal and have it removed in the programming. You can take a chance that your GM parts counter man knows what he's doing, and give him you VIN, and he can order a new key switch that you install and wire up.
You may learn more here:
www.vatssucks.com
Old Feb 25, 2014 | 06:32 PM
WVZR-1's Avatar
WVZR-1
First I believe you would/should maybe confirm that it isn't already defeated. I would first confirm that the wire from the ignition switch at the base of the column is actually connected. If it's NOT then certainly VATS has been already defeated.
That doesn't answer all questions but when you buy the new cylinder and install it the cylinder will have only a "work key" in it. Install the cylinder, connect the wire and it will either crank or NOT. If it cranks, VATS is already defeated, if it does NOT then you need to decide what to do.
Find your keys and there won't be any issues!
Old Feb 25, 2014 | 06:36 PM
WVZR-1's Avatar
WVZR-1
www.vatssucks.com
His '87 VIN and a "parts guy" will NOT accomplish a thing regardless of the "knowledge" of the parts guy. An exception would be if it were at the selling dealer when "NEW" and the parts guy had access to the prep report or the sales order to the original owner.
To 87 Corvette VATS question/problem
