89 Horn Will Not work
Old Apr 22, 2010 | 09:12 PM
drayset1010's Avatar
drayset1010
Default 89 Horn Will Not work
Allright horn to battery horn blows. replaced the relay behide info center still no joy with swith. Can someone tell me the deal with the yellow wire and cheap horn swith
Old Apr 22, 2010 | 11:40 PM
94vettelover2's Avatar
94vettelover2
Think yours are cheap,you should see the horn switch setup on my 94I would post a pic of them if I knew how(their completely plastic & break if you touch them).Bypass relay(put power to close relay & see if horn blows).If it does you know the wiring from there to horn is good & problem is between there & switch
Old Apr 23, 2010 | 07:47 AM
runner140*'s Avatar
runner140*
I knew this would come in handy:
To 89 Horn Will Not work
