Coolant leak on LT-1
Old Apr 23, 2010 | 12:53 PM
78pacer's Avatar
78pacer
Default Coolant leak on LT-1
I had the vette on the lift this morning eye-ing up my fuel filter change this w\e when I noticed a very small drip of coolant off the bottom of the bellhousing\flexplate. Are there any coolant lines above the rear of the engine that could be weeping?
Mike
Old Apr 23, 2010 | 01:25 PM
STL94LT1's Avatar
STL94LT1
There is a coolant crossover vent tube that goes from the rear of one cylinder head to the other.
Old Apr 23, 2010 | 02:14 PM
78pacer's Avatar
78pacer
Thanks,
Do they have O rings to seal the tube to the heads?
Mike
Old Apr 23, 2010 | 02:18 PM
STL94LT1's Avatar
STL94LT1
No, it's more like an A/C line gasket.
Old Apr 23, 2010 | 04:13 PM
78pacer's Avatar
78pacer
Thanks again. Are the lines accessible from the top?
Mike
Old Apr 23, 2010 | 04:37 PM
surfer92's Avatar
surfer92
Drivers side is easy to get to, but the passenger side is a PITA.
Be very careful, the bolts strip real easy.
Old Apr 24, 2010 | 06:25 AM
78pacer's Avatar
78pacer
Thanks, I'll take a good looksee when I'm doing the fuel filter this w\e. I had another thought that made me cringe. I'm praying it's not a freezeout plug...*gulps*
Mike
Old Apr 24, 2010 | 12:38 PM
JAKE's Avatar
JAKE
15 mm 6-point box-end wrench or socket is what you'll need to minimize the chance of damaging the heads of the banjo bolts.
Each banjo bolt calls for TWO washers.
Jake
Old Apr 24, 2010 | 05:14 PM
STL94LT1's Avatar
STL94LT1
I have also read of others being successful using copper washers for the banjo bolts.
Old Apr 25, 2010 | 05:06 PM
78pacer's Avatar
78pacer
Thanks guys,
I got the fuel filter off this afternoon. Now I have to p\u new O rings. You'd think they would pack those with the filter. Btw, for whomever does that job, clamp the fuel return line!! I removed both lines to speed the process up and it damn near syphoned my 1/4 tank dry.
Mike
To Coolant leak on LT-1
