I think this counts as a wtf.
Old Apr 23, 2010 | 06:09 PM
Azriel's Avatar
Azriel
Default I think this counts as a wtf.
88 coupe, 56k miles, normally has green coolant. I opened up the little plastic tank to the side that I assume is the overflow, and it's brown and looks gross. What's up with that?
Should I just clean it out?
Old Apr 23, 2010 | 06:15 PM
car5car's Avatar
car5car
flush system
Old Apr 23, 2010 | 06:18 PM
jsdomino's Avatar
jsdomino
Yes, by all means clean it out!
It probably is not anything to worry about. Fluids do get contaminated. If you haven't drained and flushed your system in a while this might be a good wake up call. The older "green" type anti-freeze was not intended to be extended life.
You should change it according to the instructions in your owners manual. However, since you have only 56K on an 1988, you need to switch to a time based interval as mileage won't work for you. Probably every 2-3 years a good flush and refill will be in order.
Old Apr 23, 2010 | 06:19 PM
Pete K's Avatar
Pete K
Yes you should.
Old Apr 23, 2010 | 06:22 PM
Azriel's Avatar
Azriel
PO hardly drove the car. It's my DD, so I've been putting miles on it.
Good, I had a flush on my to-do list.
Old Apr 23, 2010 | 07:20 PM
floridamale's Avatar
floridamale
Here in Florida because of the summer heat I do mine every year for what it costs it's great insurance to know the system is clean and working well.
Old Apr 23, 2010 | 07:39 PM
WW7's Avatar
WW7
Don't forget to use distilled water to mix with your coolant to a 50/50 mix.. This is much better for the system....you wouldn't believe whats in tap water......WW
Old Apr 23, 2010 | 07:42 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Originally Posted by car5car
flush system
Old Apr 23, 2010 | 08:11 PM
walter schweigert's Avatar
walter schweigert
I have had the same problem, I have flushed it and clean out the reservoir when I can, but it comes back every couple of years.
Old Apr 23, 2010 | 08:39 PM
383vett's Avatar
383vett
If you started with green coolant and it looks brown, hopefully it is rust and crud most of which can be flushed and cleaned out as previously mentioned. It could also be oil and antifreeze which would mean your motor is doo doo. Hopefully it is the former.
Old Apr 23, 2010 | 10:32 PM
Azriel's Avatar
Azriel
It looks like rust and crud, and not oil. I severely hope the motor isn't bad, I can't afford that right now...
Old Apr 23, 2010 | 11:16 PM
RUU's Avatar
RUU
PO may have added the GM cooling system sealing tablets - those will also turn the coolant brown.
To I think this counts as a wtf.
