aluminum radiator
Old Apr 24, 2010 | 01:11 PM
steve haverl's Avatar
steve haverl
Default aluminum radiator
I've been thinking about changing out the stock radiator for an all aluminum 2 or 3 row.
Is this a worthwhile investment, primarily with respect to lowering engine temps 20+ degrees?
Thank you.
Old Apr 24, 2010 | 02:11 PM
mako41's Avatar
mako41
I did went with a DeWitts double row all aluminum radiator. Well worth it, I highly recommend one. You may want to go with a 170*~180* thermostat and lower the temps your fans turn on, to realize the full cooling effect of a double row radiator.
Old Apr 24, 2010 | 02:27 PM
steve haverl
thank you. How do you lower the fan temp/on temperature?
Old Apr 24, 2010 | 05:22 PM
STL94LT1's Avatar
STL94LT1
FYI: Stock LT1 thermostat is 180*.
Old Apr 24, 2010 | 05:23 PM
STL94LT1's Avatar
STL94LT1
The best way is to reprogram the PCM.
Old Apr 24, 2010 | 08:01 PM
enventr's Avatar
enventr
I have a dewitts same temps as stock rad. If I changed the stat and reprogram fans it will run cooler-I left the stock fan temp and stock stat-(180). The dewitts is a great rad.
Old Apr 25, 2010 | 12:02 PM
Kool88vette's Avatar
Kool88vette
If your engine is running hot you may have other problems. Make sure your fans are operating correctly. Make sure that there's no debri blocking the air flow.
I installed a De witt's radiator. I reprogrammed the chip. The main fan now kicks on at 195F. I changed the fan sensor to kick on the aux fan earlier.
You Vette is different than my 88. My temps never get above 210 now. That's when it's very hot and running the AC. I used to see temps up around 135F. Some say that's normal but I never liked it.
Old Apr 25, 2010 | 12:14 PM
mako41's Avatar
mako41
FYI Stock L98 thermostat is 195*
To aluminum radiator
