TV Cable problem
Old Apr 24, 2010 | 03:43 PM
bigblazer1891's Avatar
bigblazer1891
Cruising
Default TV Cable problem
Anyone know how to get the tv cable out of my 92's 700r4? i cant get it disconnected at the transmission end.
Old Apr 24, 2010 | 03:45 PM
Jake Dragon's Avatar
Jake Dragon
You should be able to wiggle it out and pull the cable far enough out to unhook it.
Old Apr 24, 2010 | 03:48 PM
bigblazer1891
Cruising
thats what i thought but i cant see a hook. could it be caught up in the boot for some reason?
Old Apr 25, 2010 | 07:23 AM
Jake Dragon
You have to pull it out pretty far. If the other end of the cable is loose you may need to secure it so it doesn't move. When I did mine the cable was broken so I just pulled the cable housing off of the cable then pulled up on the cable and unhooked it. It wasn't fun but I got it done without pulling the pan.
Old Apr 27, 2010 | 03:53 PM
drkhorse's Avatar
drkhorse
Disconnect at the engine then pull the 8 mm bolt holding the housing then lift and the link it conects to will have a small "L" shaped bend in it slide it to the side and it will come out
To TV Cable problem
