high idleing on 1989 corvette
Old Apr 24, 2010 | 05:08 PM
C4 Monster's Avatar
C4 Monster
Default high idleing on 1989 corvette
Hi I have a 1989 corvette, It used to idle around 900 rpm. not to long ago I took the throttle body off and chem dipped it and rebuilt it, I also bought a new IAC valve and replaced it. Now when I start the car it will idle at 900 rpm like it used to but when I get it above 1400 rpm it will want to hang there until I rev the engine hard and make the butterfly valves snap back and then it will come back down, PLEASE HELP ME!!!!, could I have messed up on installing the IAC valve or on the plumbing with the Throttle body.
Old Apr 24, 2010 | 07:45 PM
jimmers's Avatar
jimmers
Did you do the IAC reset procedure when you installed it?
Old Apr 24, 2010 | 08:14 PM
C4 Monster's Avatar
C4 Monster
ya I did but same problem, just a while ago I put a spring for more tension on the butterfly valves and it worked, so now im sure the Throttle body is sticking. Any ideas on fixing it? thanks for the input.
To high idleing on 1989 corvette
