fluid change and timing chain ?
Old Apr 26, 2010 | 09:01 PM
kjr2492's Avatar
kjr2492
Default fluid change and timing chain ?
I have a few questions. First what rear end fluid do you use and do you need posi trac lube also? Next is what trans fluid do you use for a 4+3? Finally has anyone installed a pete jackson timing gear? I'm looking for a noisy gear drive if they make one for the 86 vette. Thanks
