Wheel Lock Key?
Old Mar 15, 2002 | 09:43 PM
Too Slow '90's Avatar
Too Slow '90
Default Wheel Lock Key?
Started to put on the new meats a while ago and found that there is no key for the wheel lock nut. The manual says GM does not keep these on record and I didn't see the card anywhere. How do I get this nut off without destroying it? All help is appreciated. :chevy :cry
Old Mar 15, 2002 | 09:48 PM
OrangeC4's Avatar
OrangeC4
Default Re: Wheel Lock Key? (Too Slow '90)
When I LOST my lugnut key, I had to have mine chisled off. Or you can take a socket that is a little to small to fit around the lugnut and hammer it on and then you should be able to take it off using a socket wrench. Or you can get one of those sockets that are universal that have pins inside the opening and try to get lucky and have it line up right. Hope this helps.
Old Mar 15, 2002 | 10:40 PM
JonM's Avatar
JonM
Your local tire store should have a tool to break them off. Your not the first person to have this problem. May cost you a couple bucks but it won't hurt your rims.
Old Mar 15, 2002 | 10:59 PM
Vette Ed's Avatar
Vette Ed
CI 4-5-6-7-8-9-10 Veteran
St. Jude Donor '07-'09
Use a 12 point socket!!!
Old Mar 16, 2002 | 02:05 AM
khornet's Avatar
khornet
From: Phx/but its a dry blast furnace kinda heat AZ
When I bought my Vette the original owner had lost the key. I took the car to the local Chevy dealer. He had their shop use some "general" GM key that was close enough to remove it. Cost me $40 to have all of them removed. Didn't make a scratch on any of the wheels. Makes you wonder how worthwhile they really are.
Old Mar 16, 2002 | 03:26 PM
Too Slow '90
Thanks all. A buddy of mine had a Mac tool for removing the lug nut. New wheels are on & look great. Thanks again for the help. :chevy
Old Mar 16, 2002 | 03:29 PM
JonM's Avatar
JonM
So after all this work posting for you we get NO Pics? :nono:
Old Mar 16, 2002 | 06:07 PM
BBA's Avatar
BBA
I bought 4 elcheapo spark plug sockets, hammered them on, and the nuts came off with almost no extra effort.
I ended up using four regular corvette lug nuts to replace the antitheft ones.
Old Mar 17, 2002 | 07:25 AM
darkredlt1's Avatar
darkredlt1
Default Re: Wheel Lock Key? (BBA)
I had the same thing happen to me. The Chevy dealer was nearby and I went there and they had a master set. I took off the locks and bought another set (4 nuts + key) for about $20. You can order another key for about $10.
Old Mar 17, 2002 | 08:55 AM
Too Slow '90
Default Re: Wheel Lock Key? (JonM)
Jeez Jon, break my ***** why don't you! It's been raining & the rest of the car looks nasty. I'll get 'em on. :crazy:
To Wheel Lock Key?
