Will Our Clear Tops Block UV's?
Old Apr 28, 2010 | 01:46 PM
CAJUN C4's Avatar
CAJUN C4
Default Will Our Clear Tops Block UV's?
I was wondering if anyone knew if the Clear tops block out UV Rays?
Old Apr 28, 2010 | 02:06 PM
surfer92's Avatar
surfer92
Never heard of one, but if there was, it would be very expensive.
Old Apr 28, 2010 | 02:15 PM
CAJUN C4's Avatar
CAJUN C4
I mean the Blue or Gray tinted ones. Not a solid top.
Old Apr 28, 2010 | 06:10 PM
surfer92's Avatar
surfer92
I know, but call Melrose or another top manufacturer.
Old Apr 28, 2010 | 08:42 PM
SJW's Avatar
SJW
I think the tinted tops on C4s will block most short-wavelength UV, but they surely don't block infrared radiation. My LT4 car gets WAY hotter with the transparent top installed than it does with the painted top on the car.
Live well,
SJW
Old Apr 28, 2010 | 09:05 PM
cv67's Avatar
cv67
St. Jude Donor '05
Temps inside were way cooler with the hard top quieter too. Id bet stiffer a bit also but who knows.
Old Apr 29, 2010 | 12:52 AM
Wiot's Avatar
Wiot
Funny you should ask that. As I was baking in my car the other day the same thought crossed my mind. My top has several large cracks in it so I'm getting a new one. I've decided I'm gonna go with a fiberglass top as a replacement and skip the acrylic one. If I want to look up and see the sun I'll take the top off.
Old Apr 29, 2010 | 01:26 AM
samsonb's Avatar
samsonb
The frame is what bolts to the car, not the top part. So it should be the same.
Old Apr 29, 2010 | 02:09 AM
cv67's Avatar
cv67
St. Jude Donor '05
What frame?
Old Apr 29, 2010 | 03:41 AM
samsonb's Avatar
samsonb
What frame?
The part the top (acrylic or fiberglass) is glued to which is the metal piece you are puting the 4 bolts into.
To Will Our Clear Tops Block UV's?
