Need Info
Old May 3, 2010 | 11:22 AM
tjblake53's Avatar
tjblake53
Default Need Info
i have a1986 c-4 smog pump locked up can i remove this without getting any goffy codes check engine lights etc i had planned to remove catalectic converter to install a header exhast system anyhow.I know i will have to install a shorter sepertene belt
Old May 3, 2010 | 07:53 PM
rodj's Avatar
rodj
Yes
You need a idler pulley to replace the smog pump because the belt will run wrong off the Alt without it
Old May 3, 2010 | 08:19 PM
383vett's Avatar
383vett
If it is because the carbon blades have disintegrated and have jammed, take it apart and use a needle nose plier to snap off the rest of the blades and clean the thing up. This should free it up. If it is the bearing, this obviously won't help.
To Need Info
