Question about my Headers
Old May 3, 2010 | 10:03 PM
rogerdoger1993's Avatar
rogerdoger1993
Default Question about my Headers
I bought a set of used TPIS Long Tube headers a week ago. Seeing as how the headers dont have Air or EGR plumbing. I am going to delete the cats. Because of this do I need to get a tune?
Old May 3, 2010 | 11:00 PM
larry00's Avatar
larry00
If you have to pass emissions you better sell them.
Sell them anyway or you will have to put in O2 sensor bungs in your pipes or it will be missing a necessary input to control the fuel / air mix.
The cats you can live without but not the O2 sensors.
You can likely find someone to put bung plugs in the headers before you put them on.
I run TPIS long tubes and they are really good pieces !
Old May 3, 2010 | 11:19 PM
cumbercr's Avatar
cumbercr
I'm running TPiS long tubes on my 85. They came with the O2 sensor fitting on one side.
Old May 4, 2010 | 01:35 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Originally Posted by rogerdoger1993
Seeing as how the headers dont have Air or EGR plumbing....I am going to delete the cats.
I don't see the connection. Front cats (especially on an LTx) rob little power, muffle, and help with emissions. What's their downside?
Is this going to become a race car?
Old May 4, 2010 | 01:39 AM
slickfx3's Avatar
slickfx3
go ahead and weld another bung for wideband....
Old May 4, 2010 | 02:50 AM
USAsOnlyWay's Avatar
USAsOnlyWay
I think you can run the cats without EGR/AIR. Won't work as well for emissions reductions but should still work.
Old May 4, 2010 | 07:07 AM
WW7's Avatar
WW7
To answer your original question, yes, if you delete egr, air, and your cats you will need a tune for it to run right..The egr delete will change your air/fuel ratio...WW
Old May 4, 2010 | 08:30 AM
tmichaud's Avatar
tmichaud
Also confused here...why do you have to delete your cats?
Old May 4, 2010 | 12:29 PM
rogerdoger1993
The headers already come with the o2 bung welded in the right spot. I was deleting the cats because I dont have to worry about emissions. This is because my car is older than 95. Also I wanted to get a little more throaty exhaust tone without the cats.
Old May 4, 2010 | 12:52 PM
surfer93's Avatar
surfer93
I have headers and cats and had the headers witout cats, the sound difference is so little. Only time there is any audible difference is at full throttle and having cats is good for the environment.
What kind of cats do you have on the car?
You want to make it sound meaner, replace the resonator w/an X pipe.
Old May 4, 2010 | 12:59 PM
GREGGPENN's Avatar
GREGGPENN
What does being older than '94 have to do with anything? You didn't mention a race application so it sounds like you just want a noisy-azz vette for the street?
Keep in mind that cats muffle in addition to converting exhaust fumes. Given the choice between deleting mufflers and deleting cats, choose the mufflers. Or, remove the resonator. If you dump everything, that summabeach is gonna be LOUD. Cats serve 2-3 purposes, mufflers only one. Try cats alone first. If you delete cats (vs mufflers), you should worry about emissions more -- cause you'll be emitting more (noxious) fumes. Just because you don't "worry" about fumes doesn't mean they go away. Between mufflers and cats, do you think cats restrict way more than mufflers? Wrong.
Also, the removal of cats is way more significant than the EGR/AIR issue.
Consider flow, sound, and function before you proceed.
Old May 4, 2010 | 05:02 PM
rogerdoger1993
Ok I guess I will keep the cats and blend them in with the stock exhaust system. Or maybe just use the cats I have now.
Old May 4, 2010 | 05:20 PM
pologreen1's Avatar
pologreen1
A weld in o2 bung is $20, or you can get the collector for $20 built in like I did from jegs or summit. you might need a heated o2 not sure.
Either way no check, then use them, get straight pipes, and be done with it.
Old May 5, 2010 | 01:26 PM
tmichaud's Avatar
tmichaud
I think that is a good idea - but no reason to not swap in new high flow versions!!!
Old May 8, 2010 | 10:10 AM
STL94LT1's Avatar
STL94LT1
FYI: You can't run factory LT1 cats with long tube headers.
To Question about my Headers
