Need Help with A/C Compressor T/S
Old May 4, 2010 | 11:10 AM
cumbercr's Avatar
cumbercr
Default Need Help with A/C Compressor T/S
The A/C on my 85 stopped working. The compressor does not engage. I checked voltage at the compressor connector and saw no volts with A/C on or off. The compressor is fairly new so I'm assuming it is good. I checked the FSM and could not find any troubleshooting procedures for the electrical to the compressor. Anyone have an idea where to start?
Old May 4, 2010 | 11:44 AM
fevest's Avatar
fevest
Check freon level. It won't come on if it is low.
Old May 4, 2010 | 12:42 PM
bac22's Avatar
bac22
That's probably the problem...but also check the fuse.
Old May 4, 2010 | 01:00 PM
383vett's Avatar
383vett
The fsm has chapters and chapters devoted to troubleshooting the hvac system. As previously mentioned, it is usually low freon that results in a dead ac system. Either get a gauge (inexpensive at autoparts stores) or jump the low pressure switch for a couple of seconds to see if the clutch activates.
Old May 4, 2010 | 01:19 PM
gaguy's Avatar
gaguy
If you install jumper wire to low pressure switch connector compressor will start pumping, your problem is that it has nothing to pump.
Low pr. sw. doesn't let voltage rich compressor if pressure is low (you probably have 0)
Old May 4, 2010 | 02:26 PM
cumbercr's Avatar
cumbercr
Thanks for the feedback guys. I guess I know where to start.
To Need Help with A/C Compressor T/S
