Heater core?
Old Mar 16, 2002 | 07:22 PM
siberianhusky911's Avatar
siberianhusky911
Default Heater core?
If the heater core was clogged would it make the collant temp soar when your drove it and would it heat work spratic at best. Or would air pockets in the radiator more likely do this Thanks Ron
Old Mar 16, 2002 | 07:52 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Heater core? (siberianhusky911)
A clogged heater core will NOT cause the engine to run hot. A clogged heater core will throw little or no heat. Sporatic heater output is usually due to a low coolant level in the system.
Old Mar 17, 2002 | 03:34 AM
GlockLT4's Avatar
GlockLT4
Default Re: Heater core? (CFI-EFI)
yes, check your coolant level. The heater core being plugged will just stop your heat from working.
To Heater core?
