Automatic shift knob removal
Old Mar 16, 2002 | 09:56 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Default Automatic shift **** removal
Well, I have another opportunity tommorow to losen my console so I can make the final connections to the last speakers.
Last time, I couldn't figure out how to remove it. I need to take the whole console cover off to clean under it. So any suggestions? Is there a set screw somewhere?
Old Mar 16, 2002 | 10:09 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Default Re: Automatic shift **** removal (jaa1988)
Lift/pull the button out and theres a Snap ring or C clip in there on the shaft that needs to be removed.Then it slides right off.
You may need the tool for the snap ring or C clip.I use snap ring pliers to push the clip apart and lift out.
Old Mar 17, 2002 | 12:36 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Automatic shift **** removal (Bill's86Coupe)
The job is easier if you have snap ring pliers, Sears has them for about $10.
If you are really good, you might be able to get it out with a screwdriver, but it won't be easy.
Old Mar 17, 2002 | 02:17 PM
siberianhusky911's Avatar
siberianhusky911
You can get it off with a screw driver and needle nose pliers. I did it on my 86 but its a pain to say the least.
To Automatic shift knob removal
