Corvette Richmond Six Speed Question
Old Mar 16, 2002 | 10:59 PM
Duntov85's Avatar
Duntov85
Default Corvette Richmond Six Speed Question
Does this tranny shift smoothly? Are the gears noisy of quiet? (I hated 1st gear in the ZF-6)
In your opinion, is is better to rebuild the 4+3, or go with something else?
Old Mar 17, 2002 | 12:45 AM
ol,RJ's Avatar
ol,RJ
Default Re: Corvette Richmond Six Speed Question (Duntov85)
well the richmond 6 isn't as smooth shifting as most stock trannie's, especially when new. and it makes more noise than the 4+3.
I think it is more durable than the 4+3 (however regular maintanence should keep the 4+3 running good).
since you don't want gear noise then a rebuild of the 4+3 would be best, its less expensive than the richmond (unless you have to rebuild it a couple of times then the total cost can surpass the richmond).
Old Mar 17, 2002 | 01:52 AM
rafzz4's Avatar
rafzz4
Hi,
I think I am more then qualified to answer this one lol.
The transmission is very noisy, but always shifts smoothly for me. It also leaks some from the case a little bit. I have contacted Richmond and these 2 things are normal, it is a race transmission after all.
On a more positive note, the gears are cut like the old M-22 Rockcrusher and the transmission is about as durable.
If you dont mind listening to gear whine in the lower gears and just general noise (although subdued by a decent motor) the richmond is great :D
Another great thing about the Richmond is the options you can specify when you order it, you can change your individual gear setups (my 6th final ratio is only .91:1 which is pretty high), goto richmondgear.com and check out the diff ratios.
I would recommend you have at least a 2.93 or so rear end, I have a 3.45 and the car is all about 1/4 mile and take off, its not good for much over 140 or so unless I want to tach the crap out of it. But that is with my ratios.
Good luck Man!!
Rich
Old Mar 17, 2002 | 05:51 PM
Duntov85's Avatar
Duntov85
Thanks for the advice. I'm going to rebuild the Super T-10/Overdrive myself. That's the only way I'll feel confident in it. Kinda like I need to build my own engines.
To Corvette Richmond Six Speed Question
