383 stroker kit
Old May 8, 2010 | 01:08 PM
2outlaw1993's Avatar
2outlaw1993
Default 383 stroker kit
im getting ready to rebuild my motor and do a 383 stroker kit...i have a 350 lt1...im haveing trouble finding the kit for a good price..any idea where i should look?
Old May 8, 2010 | 01:45 PM
aboatguy's Avatar
aboatguy
Which kit?...LT1s use the same one piece rear main seal SBC rotating assembly as the L98s and othe late SBCs.
So you just need to look for an assembly with a 3.75" stroke crank with suitable rods and pistons (usually 4.030) for your desired usage and price point.
Cast/forged US/Chinese 6.0" rods, 5.7" the brand name of the components etc .... all have a great bearing on the price .....
Mike
Old May 8, 2010 | 02:02 PM
Pete K's Avatar
Pete K
These is no such thing as a single manufacturer making all of the components in a stroker "kit".
A stroker kit is a bunch of individual parts placed in 1 big box, and called a kit.
Buy the parts you like, and assemble them.
Old May 8, 2010 | 03:49 PM
383vett's Avatar
383vett
Lunati makes a nice kit.
http://www.lunatipower.com/ProductGr...?id=185&cid=19
Old May 8, 2010 | 04:17 PM
2outlaw1993
https://shop.enginekits.com/osb/itemdetails.cfm?ID=81
this kit is not for an lt1 but why is the price so much less?
Old May 8, 2010 | 04:29 PM
Pete K's Avatar
Pete K
Because the quality is much less. Cast parts compared to forged.
With the exception of the used connecting rods. They are stock forged.
Old May 8, 2010 | 04:35 PM
aboatguy's Avatar
aboatguy
2pc seal, used rods, cast crank, cast pistons and its not balanced.....however, if you want it for your car order it with the 1 piece rms and write off the gasket since set won't work on your block and be sure to pay for a decent balance job. Just remember Fast, Reliable, Inexpensive .....Choose two....
Mike
Old May 8, 2010 | 04:37 PM
2outlaw1993
Mike
ok thanks so much to all of you for your help!
Old May 8, 2010 | 04:55 PM
BLOCKMAN's Avatar
BLOCKMAN
It depends if your looking for quality or not!! We have ben using the Callies Compstar rotators with the Mahle piston and ring kits and ACL bearings and we do our own balancing. For the money they seem to the best kits.
And like any kit every thing needs to be fitted as I have not seen any kit that is ready to assemble like the salesmen say they are.
We balance for a lot of shops and we have seen some substandard cranks as far as sizing of the journals straightness ETC.
What ever you buy it should be check out by a reputable shop that has all the proper tools.
Old May 8, 2010 | 04:56 PM
aboatguy's Avatar
aboatguy
I must surf and type too slow Pete's post wasn't there when checked the link and then I wrote my response.......and same with the blockman's compstar post on callies!
As already mentioned Lunatti makes a nice kit so does Callies Compstar....
Old May 9, 2010 | 11:16 AM
stevie1dr's Avatar
stevie1dr
You might want to check this site out for Carolina Machine engines. They built my 383 stroker and did an excellent job at a VERY reasonable price. The build took less than 2 weeks and it fired right up when installed.
http://www.cmengines.com/Engines/Per...3/Default.aspx
Steve
Old May 9, 2010 | 06:21 PM
2outlaw1993
Steve
im building mine i just need to find all the parts i need...
Old May 9, 2010 | 06:24 PM
Pete K's Avatar
Pete K
You are in luck. There are more parts and pieces for a small block chevy than there are trees in the forest.
Old May 9, 2010 | 09:20 PM
2outlaw1993
haha thats true but finding those parts at a good price is the hard part... some places carry kits that have must all the things you need in it and you just find the rest of the parts at other places...im trying to find the kit for a good price
Old May 10, 2010 | 12:24 AM
rodj's Avatar
rodj
Define a "good " price .You get what you pay for
Old May 10, 2010 | 08:34 AM
cv67's Avatar
cv67
St. Jude Donor '05
Parts are cheaper than ever remember when you wanted a new forged crank you would pay the local dealer 7-800 there was no scat eagle etc. Either that or a regrind
Old May 10, 2010 | 03:33 PM
ndanl's Avatar
ndanl
is there any big performance difference between 383 and 385 ? why not buy a 385 "kit" ?
To 383 stroker kit
Old May 10, 2010 | 09:52 PM
2outlaw1993
thats true....im looking for good quality but i dont wanta buy the best and spend 4,000....the owner of the garage i help out with found this and showed it too me
http://cgi.ebay.com/ebaymotors/1992-...item439f2f6093
im just in the looking and planning phase...can anyone tell me about this site?
2outlaw1993
i figured id spend at least that much after machine work and cam...
Old May 10, 2010 | 11:35 PM
Mark85Vett's Avatar
Mark85Vett
There are three things everyone wants...good, fast, and cheap.
Good and Cheap is never Fast
Good and Fast is never Cheap
Fast and Cheap is never Good
