Rear Lower Shock mount info
Old May 8, 2010 | 03:36 PM
LD85's Avatar
LD85
Default Rear Lower Shock mount info
Anybody know if the rear lower shock mount stud interchangeable for a 84-88 with a 88-96?
I am getting ready to buy the lower rear mounts or make my own.
Can someone give me the length of the stud from the mount face to the long end of the stud? for a 88-96?
My 1985 stud is 1.562" from the mount face to the end of the stud
http://www.vbandp.com/detail.aspx?ID=728
Old May 8, 2010 | 04:56 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
My parts manual calls for the following:
84-87: Part Num. 14044582 and says DISCONTINUED
88-96: Part Num. 14105141
You're welcome
Old May 8, 2010 | 08:55 PM
LD85's Avatar
LD85
Thanks, I know they are discontinued, I am trying to find out the difference between the 84-88 and the 89-97
If the shock mount point and the hole in the knuckle are the same, I should be good to go
I may order this setup and I only want to know if the dimensions are close to the same
$223 shipped to the US
Old May 8, 2010 | 09:53 PM
rodj's Avatar
rodj
For a old timer I took a pic for you.
Late mount has approx 3/4" shoulder to locate shock further out for clearance because shock on late cars is vertical ; not angled in as on early cars.
You are also aware the early bottom mount is angled down to accomodate this ; not horizontal in the knuckle as on late cars
Rough tape measure length
Early 2 / 16"; mounting face to end of shock mount ( not including thread)
Late 2 7/8"
Old May 8, 2010 | 10:00 PM
LD85's Avatar
LD85
Late mount has 3/4" shoulder to locate shock further out for clearance because shock on late cars is vertical ; not angled in as on early cars.
You are also aware the early bottom mount is at a angle to accomodate this ; not horizontal in the knuckle as on late cars
rodj, you my friend,,, are the man this is exactly what I had hoped to determine, now i need to figure out if I need to make my own mount or stick with the stock angled setup..
btw, I ran 6 miles today,, i refuse to get old
Old May 8, 2010 | 10:06 PM
rodj's Avatar
rodj
Didn't you already do the mod to mount the coilover on the early angled setup by using a offset top mount for coil clearance?
Old May 8, 2010 | 10:35 PM
LD85's Avatar
LD85
Yes, I moved the upper mount forward for clearance.
But the custom mount in the pic above would move the moment farther away for the knuckle and it would be on a down angle as well, I need to think about his some and figure out if the down angle matters
I can make my own lower and bring the down angle up to horizontal but I want to make sure that this is a good idea.
Old May 8, 2010 | 11:05 PM
PLRX's Avatar
PLRX
2017 C4 of Year
PM sent
Old May 9, 2010 | 07:06 AM
LD85's Avatar
LD85
THe kit above is from ACP
http://www.acp-euskirchen.de/index1.htm
To Rear Lower Shock mount info
