what scan tool to use
Old May 10, 2010 | 06:58 PM
smile5's Avatar
smile5
Default what scan tool to use
Hello ,I recently purchased an 85 Corvette and just wanted to know what would be the best scan tool to use on this particular year of vette, this is my first corvette and any info would be appreciated. Thanks
Old May 10, 2010 | 08:10 PM
Gazpar's Avatar
Gazpar
Similer thread here:
http://forums.corvetteforum.com/c4-g...questions.html
Answers some of the basic questions, and has a few good links
Old May 10, 2010 | 08:16 PM
powerpigz-51's Avatar
powerpigz-51
The best scan tool is a laptop and a ALDL/serial or USB cable adapter. I am not sure if there is a scan tool that actually functions with the 870 ECM and it's slow 160 baud rate. Go to Moates.net....they will not list the 85 ECM specifically, but you need the ALDU1 adapter and cables and TunerproRT (software). I just went through what you are going through....so hit me up with Q's if you like.
Old May 11, 2010 | 05:07 PM
rons85's Avatar
rons85
It's an OBD-I system, ANY professional scan tool (with the proper early GM ALDL plug adapter) will work. Try looking on fleabay for a decent used Snap-On or Matco scanner - the older stuff goes Cheap.
I personally still have a Snap-On MT-2500. Obsolete now (no longer being updated for current vehicles) but until it dies (if it ever does) it works fine for the vehicles it Does cover.
I also use a laptop and either WinALDL or TunerPro (and I have TunerCat as well). The dedicated scan tool is handier, quicker and easier to connect and use. For diagnostic purposes it is a better choice.
Old May 11, 2010 | 06:38 PM
smile5's Avatar
smile5
Thanks to all that have replied, alot of info that is very much appreciated. now to go and buy more parts for the vette.
Old May 12, 2010 | 12:00 PM
powerpigz-51
Thanks for chiming in Ron, as I hate to give out the wrong info. In my searches for scanning the 85, some people were having problems with a particular (popular) scanner that would not work with the 870, and they even contacted the manufacturer, who said it would not work. I just can't remember which scanner it was. So my bad.
Old May 23, 2010 | 04:42 PM
ckvlvette's Avatar
ckvlvette
8th Gear
I have a AutoXray and it says it works on '86 on
To what scan tool to use
